SONOS and Soundboard
I have a SONOS S2 system and I would like to use the Soundboard app to play a custom MP3 sound.
I have installed the Soundboard app and uploaded a MP3 file. If I hit the play button, I can hear Homey playing the MP3, so I know that the MP3 has been uploaded to Homey correctly.
But when I create my flow, and select the “Play a Soundboard sound”, SONOS will not play the custom sound. Even if I hit the “Test” button, nothing gets played. Homey only shows a green tickmark that the command has been executed.
Is the Soundboard app broken?
FYI, if I use the “Play a Sound” option and select one of the predefined sounds, it works as expected.
Works for me without any problems:
But of course, you have to choose the MP3 file:
If no sound is available, maybe it helps to restart the Soundboard app.
Sonos App: v6.2.1
Soundboard App: v3.0.1
I have the same versions of those apps.
I can see all the uploaded MP3s on the Soundboard app, and I can also select an MP3 file. So the flow looks fine. Except that it does not play any sounds on my SONOS.
I have restarted the Soundboard app, but still nothing is being played.
It looks like something is blocking Homey from playing a sound over my network…
No problem here also, did you look at the volume?
Yes, I have tested it with different settings of the volume, nothing is being played (no sound).
I had same problem that some MP3’s didn’t play.
I re-encoded the MP3’s and can play them all now.
If I use the “Play URL” on the same MP3 (https://homeycornelisse.nl/wp-content/uploads/2020/05/Countdown-10-sec.mp3) then SONOS will play that MP3 without any problems.
If I download that MP3 to the Soundboard app, I hear nothing :frowning:
Are you sure the Amp is a S2 device and not a S1. I have an older Play-Bar (S1), and that one can not play from Soundboard, while the newer Play-One can.
The AMP is listed as S1 and S2 compatible. I will run some test if I can play something on my Arc.
Hi @Hamster, there is a test version of the Soundboard app available (Link).
Changelog:
Version 3.0.2 — Fixed an issue for Sonos.
So maybe this version will fix your issues.
v3.0.2 fixes the problem, I can now hear the MP3 being played on my SONOS!
The same problem with these:
Soundboard
v3.0.3
Sonos
v6.2.5
SOME files will play. other not.
EDIT:Converted them again, all 9 .wav-files is OK as .mp3.
Bug or feature?
Don’t know.
Have you compared the files which can be played and which cannot be played? Size? Stereo/Mono? Sampling rate? Bit rate?
Hi Dirk, thanks for your reply.
No pattern which can be to help. Deleted the «old» .wav-files when .mp3-files worked.
Sorry… :see_no_evil:
No problem.
