[HOWTO][PRO] Use SoundBoard with Google Chromecast
:rotating_light: Officialy supported in Google Chromecast app since version 6.0.3. Google Chromecast | Homey
I was searching for a while to play SoundBoard sounds via my Google Chromecast.
I found a way how to do this.
Requirements:
Steps:
    • Install the soundboard app and Chromecsast app
    • Go to App settings
    • Click on SoundBoard and upload a mp3
    • Delete all commands in the input field
    • Paste this command:
      Homey.apps.getAppSettings({id: 'com.athom.soundboard'})
    • Copy sound ID
    • Create a flow in Homey
    • In the THEN part use the Chromecast Cast Sound card with the following url:
      http://HOMEY_IP/app/com.athom.soundboard/userdata/SOUND_ID.mp3
Contributions
If you appreciate what I do, contribute to future development by making a paypal contribution
or buy me a coffee on Ko-Fi or Bunq.me
image ko-fiimage
:laptop: Apps made by @martijnpoppen
See for more apps link below :backhand_index_pointing_down:t2: or just open the pull down.
It works also with the Sonos app. So I guess it will work with every entertainment system where you are able to play something from URL.
Thanks for the great tip! :+1:t3:
@DirkG you’re welcome :slight_smile:
Sonos has a integrated Flowcard for this. So that’s what triggered me to find this out
Thanks, this works almost perfectly. The only thing I do not like is that my Chromecast first plays its “wake-up sound” and then the sound-effect I uploaded. Is there a workaround for this?
@DGalama nope unfortunately not. That’s in the Chromecast app
Too bad, I already suspected that.
Strangely enough it does not always play the wake-up sound, but I have not figured out what causes it to play or not play. Probably some time-out.
Thanks for your quick reply!
Thank you @martijnpoppen .
That worked. Happy with that. Now i’ve fixed another problem with your solution when i go to the homey pro 2023 without a speaker.
One question. Is it possible to remove the soundboard app from homey when i followed your solution, or will this also remove the sound mp3’s?
Thanks again.
@Pieter_Pessers You’re welcome! :slight_smile:
Unfortunately that will remove the mp3’s as they are tied to the app itself
I’ve tried the same command in Homey dev tools, it show only
Response
“root”:{1 item
“id”: string"com.athom.soundboard"
Am i doing it wrongly on my HP2023 ?
@Shiki did you upload a mp3?
Yes, existing i have 8 mp3 files before i migrated from HP2016. I just uploaded one more mp3 file, but running the command still the same. Not sure what am i expecting :thinking: from the results .
Sorry for the late response. But if you only get back the ID it means that there are no app settings.
Can you check the settings of soundboard? :slight_smile:
Hi, here is the setting I have in soundboard on my HP2023. Is there anything else I have missing ?
hmm that’s strange,
Can you try to upload an new mp3?
Just trying to find out if there is something wrong after migration :smiley:
Uploaded a few more mp3 still the same, it does not show any sound ID in the Web API Playground.
I also tried deleted the Soundboard App, re-installed and uploaded new MP3 too but it is same the same, no sound ID output.
Yes, i’ve migrated from HP2016 to HP2023. Not sure if i am only one facing this issue. :thinking:
@Shiki it seems related to the new Homey. Can you run the command and send a screenshot of the output?
Don’t think a lot of people use this tutorial for Soundboard :stuck_out_tongue:
Here the screenshot:
@Shiki can you try this?
Homey.apps.getApp({id: 'com.athom.soundboard'})
yes, there the output:
This function isn’t available in the used homey-api on HomeyScript nor the developer playground for Homey Pro (early 2023), it indeed will only retreive the ID and that is it.
Both need to update the homey-api package used.
