Pls report the Bug to Athom using the official support, Guess they already know about the bigger eMMC but need to Fix something in the code (if that is the Issue)
Else they help you with the real issue why it fails.
I have also seen it fail several times at the same place (Wherever that was between lets say ~50 and 100%, also verified it with Dev. Console to be every time at the same block) with my Original Homey with 8 GB eMMC, until I used another Short Cable and I guess another USB port.
I don’t assume a relation between the original 8 GB and bytesRead=5498732544, I will Let that up to Athom Developers.
Can you verify using a Linux host or Jailbreak if it is still using the same Partitioning ?
Looks like it’s formatted for 8GB ![]()
32GB is available in Home Assistant ![]()
It’s purchased directly from Athom ? I believe they would advertise such change…
Just speculation: Or it is ‘just in the background’ to have more flash that can be used? (load balancing and spreading the read-write actions?)
My guess is that there might have been a (temporary) issue with getting 8GB modules, and they replaced it with a 32GB to be able to meet demand.
They wouldn’t advertise it because people might start expecting to get a 32GB module and will start complaining when they get the regular 8GB version ![]()
It probably has to do with the poor availability of CM4.
I just did a complete USB backup of my 32 GB Homey Pro 2023, and had no issues. I guess that doesn’t really mean much, other than the fact that either they made some changes in the backup script, or this is an intermittent issue that depends on different factors. I used the same computer/port/cable as I have previously.
Maybe eMMC is dying in my Homey.
Always stops while reading “bytesRead=5498732544”
Hmm, just tried an usb backup again. They changed the script again as far as I can see (less info in console). Backup now completed successfully ![]()
CM4108032
Same here!
USB backup working on CM4108032 ![]()
Now I checked it and it also works. ![]()
Ok, so then they fixed it. Good! However, it would have been great to have the possibility to do this locally, so if they break it again, backups can still be made.
Yes. Exactly what I want. It is not complex to download the scripts. But did not found a way to run them locally. The older script was also giving info about % completed and what block it was reading. The console is now nearly empty. Anybody an idea humor to run this script local/offline?
Tried it today and get it working via gparted. I also had to install apt install rpiboot and after that make an sudo rpiboot on terminal to get the connected Homey in DFU mode working on my raspberrypi os as external usb device. After that i changed the partitions and everything worked like a charm. Thank you!
