Lose all <> symbols! Only the Homey ID should be entered between https:// and .connect.ath… and, the token should be the exact token, not with added < >
like: https://62xxxxxxxxxxxxxxxxxx.connect.athom.com/api/app/nl.scanno.owntracks/events/f8xxxxxxxxxxxxxxxxxxxxxxxxx
Sorry if this is a stupid question. But how do I copy the user token? I can see a string of tekst but no way to copy it. For now I used OCR to get it but I always get a 404 in the OwnTrack app. Do I do something wrong?
The coordinates don’t change, these are pre-defined geofences, and available in flows as trigger- and conditional cards, by the geofence names you defined
True, Macrodroid is great.
Location & Presence has no “live” GPS coordinates on board.
I would appreciate it very much when you update or remove your post when you solved it yourself.
Now I spent time on your question for nothing
Saying ‘Thanks’ is also a small effort, but much appreciated.
I’m very grateful for all the help and input from everyone in the Homey community. I’ll edit the post. It wasn’t my intention to put you through unnecessary work. Thanks!
Try deleting “?token=” in the url if you followed the original post instructions. So the URL looks like this:
https://.connect.athom.com/api/app/nl.scanno.owntracks/events/
