How to login via local network address
I have tried to login in to my homey device using my 192.168.x.x:4859/web/login-local address, but my user id and passwords do not work. What am I doing wrong?
Follow the instructions carefully: https://support.homey.app/hc/en-us/articles/22924537226268-Set-up-Local-Users-on-Homey-Pro
Thank you that worked
how do you add a local user when you can’t login in locally?
Log in to the web app and follow this instruction: Set up Local Users on Homey Pro.
What an idiotic way to do things
Did you get it working?
I guess. I was able to get a local user set up, but thats about it. Think i’m going to stick with HA, this is way too complicated, can’t find any of my devices, no apps for anything I use. Even to do the most simplest of things requires a phone.
Which devices are you missing? In my case, it’s actually the other way around: Homey has apps for many devices that HA doesn’t support
Leviton lights, I’ve got about a dozen that are wifi but homey needs some adapter, tapu cameras, and a Chinese diesel heater. That I might be able to get working with my broadlink. also couldn’t connect it to tailscale but that isn’t too important since it would be offline pretty much all the time and from what I’ve read, homey doesn’t work offline very well.
Maybe via Tuya?
I think you mean Tapo? Those are supported, I have some of these cameras as well
You can always request an app in the App Requests topic
