I pushed this button to test the smoke (and CO) detectors, like ypu would do with normal detectors.
That gives an acoustic alarm on the detector itself, and triggers the alarm-flow on Homey (only not on the one in the sleeping room which probably is too far away).
The triggering sets the detector to an alarm state in Homey which does not reset.
Unfortunately there is no card to reset an alarm from these sensors in Homey.
That means you would have to press the button within with a needle after each testing?
EDIT: pressing the button behind the small hole does not result in resetting the alarm-state…
Wouldn’t adjusting the wake-up interval not help here?
Or might this significally increase battery usage, you think?
