How do I update SHS on VMWare (Windows 11)
I have subscribed to test releases, I get notifications of Release Candidates.
On the Web interface I get an option to dowload and install the update but it fails with
The VM console says Invalid Endpoint: ManagerUpdates.getOptionAutoUpdate. If I restart the VM, early on in the log output it says sometinhg about not finding the update.
And to make matters worse, I get an error when I try to creater a Diagnostics Report.
I know from looking at the output of ‘ps -ef’ that SHS is running n a Docker container but it would help if there was some info on how to update that manually (and where the container is).
I am using SHS instead of HomeAssistant to avoid the endless hacking and digging :slight_smile: I would love to get past this hurdle, it is one of the last before fully switching over.
You cannot update SHS from the web app, you need to manually update (you can find instructions for updating at https://support.homey.app/)
If you have a direct link that would be helpful, otherwise……
I had already searched very thoroughly for the word Update including at that link. Other than saying how to enable experimental there is Nada about how for SHS in VMware or Virtualbox.
Also, if it is supposed to be manual operation, why is there a clickable button on the web interface to Download and Install? As stated, Auto update can’t be set, it throws an error in the log. So restarting the VM results also in no update.
I also Iooked in the Dutch language section with no result.
From the Homey website:
This means that you just need to reboot it for the update to install
It returned every ‘self hosted server’ howto except for the Windows one :man_shrugging: (inform support I’d suggest to update the knowledgebase search)
On the other hand, searching for windows or self hosted would’ve made your day;
thank you for those links. I guess it is all in what words to use for a search, I really did look :slight_smile:
But as stated, while I signed up for the beta’s, at the beginning of the start of the VM there is a message stating it can’t find the updates. I’ll try to catch it in a screenshot on Friday.
I really don’t want to explain to my wife how to do docker updates inside a VM.
Why should you? You are not obligated to do an update at a specific moment. You can do it yourself when you have time for it.
My point really was that I shouldn’t have to learn how to do this if ther e is a Download/Install button.
I will figure it out, because at some point I will want or need to do an update to a Beta version. In meantime I will revert to Official and cycle the VM when there is a new release in that channel.
@Peter_Kawa I will suggest an update to the knowledge base. Bedankt voor de suggestie
Figured it out:
When you enable Developer Mode, this is the message for SHS
In the VM you would have to modify the /etc/systemd/system/70-homey-shs.service file and restart the VM. You will (should) then get the Beta feeds from then on.
Or follow the update instructions in the SHS Linux install if you want just an occasional Beta update. Linux Install
As a footnote, if you login to your SHS with a Local user account, you will see the AutoUpdate option, if you login using the https://My.Homey.app page there is no AutoUpdate option.
Sorry Is this for the 12.12.0
I followed the instructions and it took me through the set up of SHS again. Went to the Broadcom site and the file was the same as the previous download.
Where is the update? Why is there no auto update option like in HA?
The question was how to update SHS on VMWare, no need to go look at Broadcom site.
For latest, e.g. 12.12, you officially power down and restart the Homey-SHS VM. That is supposed to get the update and run it. So in essence the same as HA auto update. Sometimes it seems to take 2 tries.
Someone reported that they had to change network config in the VM to NAT instead of Bridged.
Some ppl want to get Beta versions, that you have to do manually using Docker commands as shown in the Linux install.
Ok thanks. Tried shutting down the vm several times. Nothing.
I went to the broadcom site because their guide says nothing about updates only about install on VMware so i assumed that they had a newer version for download in there as per original build
How to install Homey Self-Hosted Server on Linux – Homey Support shows the Docker commands to get the latest SHS version.
