Hi all,
After my homey pro has updated to 12.1.0 it goes sporadically offline and then online again after a few minutes. Does anyone else also see this behaviour? If so does anyone know how to fix this? ![]()
Hello, my Homey pro was offline after the update. The light was red. I rebooted it and it is fine. First time an update makes this. All my morning flows did not worked, this is not a big issue because I was at home but if you rely on Homey and are not at home, you should disable the automatic update… good to remind this.
Such problems related to a firmware update should always be reported to Athom Support (link), even if they can be solved by restarting the Homey or PTP.
Thanks for the feedback I’ll try if another reboot will solve the issue and log it via the link👍🏼
