Ich bin wirklich neugierig, was “Empfang von 433 MHz-Nachrichten über Satellit” bedeutet.
Hoffentlich empfängt die Homey Bridge, konfiguriert als Satellit, 433 MHz Nachrichten und sendet sie über WiFi an Homey Pro. So dass die Reichweite des 433 MHz-Netzwerks wirklich erweitert wird.
Homey Pro (Early 2023) v10.3.1 has been released to the stable channel.
Core
- Fixes an issue where Apps would not receive install and uninstall events.
- Fixes an issue where Apps would always enable auto updates after an update.
- Fixes an issue where time would not sync correctly.
- Fixes an issue where images would not be shown in a camera view.
- Fixes an issue where a cloud back-up could fail temporarily.
- Fixes an issue where permissions for app-to-app communication was not checked correctly.
Zigbee
- Fixes an issue where devices were not made available again when they rejoined.
- Fixes an issue where errors were not shown in the repair screens.
Z-Wave
- Improved start-up behaviour.
- Improved flashing reliability.
RF & IR
- Adds support for receiving 433 MHz messages via a Homey Bridge Satellite.
- Fixes an issue that caused Infrared & RF signal repetitions not to work as expected.
Homey Pro (Early 2023) v10.3.2-rc.1 has been released to the beta channel.
Core
- Fixes an issue where if both Ethernet and Wi-Fi are connected Homey Pro could experience connectivity issues.
- Fixes an issue where weather data would not update after the region of Homey Pro changed.
- Fixes an issue that caused a delay in setting the capability value of a Virtual Button device.
Back-ups
- Fixes an issue where restoring a back-up could cause Homey Pro to go into set-up mode after a reboot.
Z-Wave
- Fixes an issue where Z-Wave would not work in Malaysia.
- Fixes an issue where Z-Wave errors were not translated for basic Z-Wave devices.
- Fixes an issue that caused Satellites to not join the Z-Wave network as router when using the region override setting.
Zones
- Fixes an issue that could cause delays in updating zone activity.
- Fixes an issue that could cause zone activity Flow cards to trigger multiple times for a single change in activity.
Homey Pro (Early 2023) v10.3.2-rc.2 has been released to the beta channel.
Core
- Fixes an issue that could return an invalid error when connecting remotely.
- Fixes an issue where the image of a virtual IP camera could not be send as a push message to an Android device.
- Updates translations.
Hat jemand von Euch schon Erfahrungen mit den letzten beiden v10.3.2-rc.1 und 2 gemacht?
Hi Dirk, hab eben auf die RC2 aktualisiert. Vorher hatte ich die RC1. RC1 war völlig problemlos. Bei der RC2, konnte ich bisher auch nichts negatives feststellen.
Homey Pro (Early 2023) v10.3.2 has been released to the stable channel.
Core
Back-ups
Z-Wave
Zones
Update läuft . . . . Homey ist wieder online.
ja liefen problemlos - bei rc2 hatte ich allerdings Verzögerungen gemerkt im System… auch nach Reboots…
seit ein paar Minuten habe ich die v10.3.2 drauf
Mir ist bereits bei den rc-Versionen aufgefallen, dass der Status einiger Geräte nach dem Update nicht stimmte. Nach dem gestrigen Update auf die offizielle v10.3.2 war der Status folgender Geräte falsch:
- Vibrations-Alarm eines Aqara Vibrationssensors war aktiviert
- Bewegungs-Alarm bei einem Fibaro Motion Sensor war aktiviert und der Status lautete “Vor 2 Tagen”, dabei wurde der Bewegungs-Alarm noch am selben Tag getriggert
- Ein einfaches On/Off Advanced Virtual Device (Device Capabilities App) war nach dem Update eingeschaltet, was es vorher nicht war
Hier im Forum habe ich keine ähnlichen Meldungen gefunden, aber auf Slack wurde das Problem auch von einem anderen User gemeldet (Link).
Dieses Phänomen habe ich ebenfalls. Es sind nur die Geräte der Device Capabilities App.
Bei mir sind es ja Zigbee, Z-Wave und DC Geräte. Deshalb würde ich prinzipiell ein App Problem eigentlich ausschließen.
Das kann ich bestätigen. Mir ist das gestern erst im Laufe des Abends aufgefallen.
Folgende Geräte haben einen falschen Status angezeigt:
Shelly BLU Fensterkontakt
Devolo Bewegungsmelder
Shelly Motion 2
Device-Capabilities Schalter
Bitte prüft das mal. Bei mir wird der falsche Status auch nach einem Neustart von Homey angezeigt.
Das ist mir erst nach dem Update auf die v10.3.2 aufgefallen.
TIP:
Habt Ihr das ganze auch via DeveloperTools kontrolliert ? Denn ich habe festgestellt das die neue (iOS) Homey.app ziemlich “buggy” ist. Mir ist bei den neuen Zonen-Kacheln aufgefallen, dass bei Devices mit der "class: “other”, die Werte nicht angezeigt werden, aber in den DeveloperTools sind sie vorhanden.
BDW: Habs für Licht gemeldet, aber Ihr wisst ja, wie lange so etwas dauern kann…
Nein, habe leider keinen Quercheck in DevTools gemacht. Allerdings war das On/Off AVD definitiv eingeschaltet, was es ja nicht hätte sein sollen, da ein Flow nicht so reagierte, wie er hätte reagieren sollen. Nachdem ich das AVD in der Smartphone wieder ausgeschaltet hatte, lief der Flow wieder problemlos.
Das Problem mit dem angeblich seit 2 Tagen dauerhaft getriggerten Motion Sensor konnte ich ganz einfach beheben, indem ich diesen einfach ausgelöst hatte. Seit dem funktioniert der auch wieder einwandfrei.
Ja ebenso bei mir, auch beim 19er, shelly blu , 2 Geräte zeigen immer Bewegungsalarm. Die shelly app zeigt keine Bewegung.
Bitte meldet das Fehlverhalten an Athom.
Was mir jetzt aufgefallen ist das bei Zonenaktivität, Sonnen auf und Untergang, man jetzt selber den Abstand in Minuten bestimmen kann. Vorher war es vorgegeben 1,2,5,10 bei Zonenaktivität
Homey Pro (Early 2023) v10.3.3-rc.1 has been released to the beta channel.
Core
- Fixed an issue that could cause Homey Pro (Early 2023) to show a white spinning LED ring indefinitely when booting without an active internet connection.
- Improves the way Homey Pro (re-)connects to the cloud.
