Homey on ethernet could not find wifi devices
My homey pro is on ethernet cable and since then it does not find local wifi devices any more? Before i was on wifi with the homey and then it find all the wifi devices… how to fix this. I ve spend 29 euro for the adapter
This is a local networking issue, it sounds like your WiFi network is separated from your wired network for some reason.
When you go to this page and scroll down, you should see two fields “wifiAddress” and “ethernetAddress”. What are they?
Ethernet 192.168.178.47
Wifi 192.168.68.82
De homey zit op een tp link switch
From the ip range you can see that your wired and WiFi network are different networks. So your Homey is not able to discover devices on your WiFi network.
Problem fixed by changing the mesh routers to acces points instead of router mode
