I know, I know, but it ll reset after time. And I d love to see them all together. I ll try to make a node red dashboard soon
serve
Static file serving and directory listing
Never reset in my case on one device. Using it on wall mounted tablet and kiosk browser and it remains same also after restarts.
Have a look here, seen pictures with all the values visible in the same tile.
That’s nice, is that just a sketch or a working dashboard?
It’s a working dashboard. Took me some weeks to accomplish. Not fully satisfied yet, but works good enough for now.
I have a second dashboard that shows last connected/reported times and want to integrate that into this one. Can’t get it right though (can’t get all info on the tiles in a decent way), my json knowledge is too limited.
Adjustments I made (as is, I still have to run a diff with all edited files
I’m familiar with coding, but far from guru
So you’re on your own using this.
To show all available values on tiles, edit this file:
/app/css/themes/web.css
Or use iphone.css / ipad.css / google nest hub.css instead, if you use one of the iphone/ipad/“google nest hub” templates as your theme on your device.
Find the line with:
.device .value {
Then change
position: absolute;
into
position: sticky;
-Font adjustment:
This is also done here:
.device .value {
Changes made:
top: 0.4vh;
right: 0.4vh;
font-size: 2.2vh;
font-weight: 500;
line-height: 3vh;
max-height: 2.6vh;
And at the entry below that,
#decimal {
change the font size for decimals:
font-size: 1.8vh;
The same theme for an android 10.1 tablet works for my android phone as well
@JPe4619 Jan, it is not functional (yet) though, but ik looks a bit like it.
What you see here are tiles ‘longpressed’, so they show a value it otherwise doesn’t.
The tiles keep this ‘state’ on a tablet f.i., but not on a Ggl Hub. I think cookies do the trick of ‘reminding the state’.
Using the online dash and casting it to a ggl hub, you will be pressing the tiles every x minutes to show the values you want…
From what I understand the only way for now is to download an run the dashboard locally.
So, I’ve used the online version previously but I have decided to run locally on my rpie instead. Got it up and running and I can see the dashboard when going to the IP of my rpie with the token string attached.
I SSH in to my pie and cd in to homey.ink and run serve -p 5000 app.
Problem is that when I close my ssh connection it seems like the dashboard stops working, how come? I’m a novice when it comes to linux so any help would be appreciated.
What does serve --help say?
I guess you have to do something like this, the run forever option
(found online, so don’t kill me if this is crap):
You need to specify the absolute path for the folder you want to serve, and also use which to get the command absolute path as well.
I use npx to run serve instead of having it installed, and it works like this:
forever start $(which npx) serve -l 80 -s /home/user/folder/build/
or what about entering this
npm i -g serve
git clone https://github.com/Homeycornelisse/homey.ink
cd homey.ink
serve -p 5000 app
I’m thinking if you only enter the last command, it quits when you disconnect. But maybe I’m talking crap and should not interfere
Not getting it to work. Tried
npx forever start $(which npx) serve -l 80 -s /home/draceus/homey.ink/app
output is
npx: installed 235 in 23.712s
warn: --minUptime not set. Defaulting to: 1000ms
warn: --spinSleepTime not set. Your script will exit if it does not stay up for at least 1000ms
info: Forever processing file: /usr/bin/npx
Not sure what Im doing wrong. Surely everyone running this locally has it set up so it doesn’t stop working when you close SSH to the server. Must be someone who knows the answer ^^
Using the dash on a local host, i was trying to get the weather icons working again, like the sun icon in the screenshot.
Appearantly for a while now, the wheather descriptions changed into the language of your location, for me it is NL and the language is Dutch, instead of English (b/c the default weather icons all have English names).
So, I renamed the weather icons to Dutch, and that works. → The weather descriptions used can be found here
Well, it works for one word descriptions like ‘bewolkt’, or ‘helder’, but not when the description has two words like ‘lichte regen’ ‘half bewolkt’.
Can anyone give a hint how to escape the whitespace?
I tried halfbewolkt.svg and half bewolkt.svg for instance, but no luck.
Thanks in advance,
Peter
I found this solution, this removes all whitespaces from the weather data string.
// First, remove possible whitespaces from weather description
let $WeatherStateNoSpace = weather.state.toLowerCase();
$WeatherStateNoSpace = $WeatherStateNoSpace.replace(/\s+/g,'');
$weatherStateIcon.classList.add($WeatherStateNoSpace);
$weatherStateIcon.style.backgroundImage = 'url(img/weather/' + $WeatherStateNoSpace + dn + '.svg)';
$weatherStateIcon.style.webkitMaskImage = 'url(img/weather/' + $WeatherStateNoSpace + dn + '.svg)';
For the info panel, apply the like:
$icon.id = ('weather-state-icon');
// first, erase possible whitespaces from weather description
let $infoStateNoSpace = info.state.toLowerCase();
$infoStateNoSpace = $infoStateNoSpace.replace(/\s+/g,'');
$icon.classList.add($infoStateNoSpace);
$icon.style.backgroundImage = 'url(img/weather/' + $infoStateNoSpace + dn + '.svg)';
$icon.style.webkitMaskImage = 'url(img/weather/' + $infoStateNoSpace + dn + '.svg)';
EDIT Tested and it works.
“Licht bewolkt” is converted to “lichtbewolkt” and finds my “lichtbewolkt.svg”.
So, the icon files should not contain any whitespaces, f.i. partlyclouded.svg or heavythunderstorm.svg
List of Dutch weather descriptions (received from Openweathermap by mail, thanks feRon):
200: onweersbui met lichte regen
201: onweersbui met regen
202: onweersbui met zware regenval
210: lichte onweersbui
211: onweersbui
212: zware onweersbui
221: onregelmatig onweersbui
230: onweersbui met lichte motregen
231: onweersbui met motregen
232: onweersbui met zware motregen
300: lichte motregen
301: motregen
302: zware motregen
310: lichte motregen/regen
312: zware motregen/regen
313: stortbuien en motregen
314: hevige stortbuien en motregen
321: zware motregen
500: lichte regen
501: matige regen
502: zware regenval
503: zeer zware regenval
504: extreme regen
511: koude buien
520: lichte stortregen
521: stortregen
522: zware stortregen
531: afwisselende stortbuien
600: lichte sneeuw
601: sneeuw
602: hevige sneeuw
611: ijzel
612: lichte ijzel
621: natte sneeuw
622: hevige sneeuw
701: mist
721: nevel
731: zand/stof werveling
751: zandstorm
762: vulkanische as
771: rukwinden
781: tornado
800: onbewolkt
801: licht bewolkt
802: half bewolkt
803: zwaar bewolkt
804: geheel bewolkt
I tried
halfbewolkt.svgandhalf bewolkt.svgfor instance, but no luck.
half%20bewolkt.svg should do the trick I think…
You’d expect that, but that didn’t work either.
In my post above yours you can see it’solved by removing the whitespaces from the weather description string with a find&replace function, and naming the icon files also without any space, like ‘verylightrain.svg’
EDIT Solved!
Thanks to Arie Godschalk, this is the fix:
capabilityObj['cap.text1']
instead of:
capabilityobj.cap.text1
Hi Emile, or other dash devs,
I run homey dash locally
In the homeydash.app.js file, I wanted to add a capability with a dot in it’s name.
But it does not work, while a dot has a funcion. Does the dot have to be escaped?
And how? measure_rain\\.1h did not help.
Or should dots in capability names just be omitted by app devs?
// Not working because of the dot in *measure_rain.1h*
if ( device.capabilitiesObj.measure_rain.1h ) {
device.makeCapabilityInstance('measure_rain.1h', function(value){
var $deviceElement = document.getElementById('device:' + device.id);
if( $deviceElement ) {
// var $rain1h = ( ":measure_rain.1h" )
var $valueElement = document.getElementById('value:' + device.id + ":measure_rain\\.1h");
capability = device.capabilitiesObj['measure_rain.1h']
renderValue($valueElement, capability.id, capability.value, capability.units)
I’d like to color the tile also from apps which use dots in the cap.names.
I use this code for that:
if ( device.name == "Temp Vriezer" ) {
if ( device.capabilitiesObj && device.capabilitiesObj.measure_temperature) {
var temperature = device.capabilitiesObj.measure_temperature.value
console.log(temperature)
if ( temperature < -10 ) { // value below -10, tile gets iceblue
console.log("temperature out of bounds")
$deviceElement.classList.add('lowest') // lowest == tile gets colored iceblue
}else{
$deviceElement.classList.remove('lowest')
if ( temperature > -9 ) { // value above -9, tile gets red
$deviceElement.classList.add('high') // high == tile gets colored red
}else{
$deviceElement.classList.remove('high')
I hope this isn’t too stupid, but…do you have experience running this from a docker? I was hoping to run it on my NAS and serve it to multiple units.
Hi there,
How can I disconnect homey.ink access to my homey pro ? I’m not comfortable with the open online access to my homey box from a simple URL.
Thx
