Homey.ink on a tablet/desktop
Hi, please check the code above. There is a line with “device.makeCapabilityInstance”. This registeres an event handler. When the capability in Homey devices is changed, the Dashboard will execute the code inside the { } brackets.
There you can change your div-element.
Here is another example where I change the color of the displayed temperature when the thermostate temperature is changed:
I think that is what you wanted to do. Good luck :slight_smile:
I use HomeyDash on an old Ipad3 mounted on the wall. I use it on the internal battery. No wires needed. After some minutes not using the screen of the Ipad go to standby and the screen is off. That’s fine. After pushing the on switch the HomeyDash app is directly visible but without actual data. Some lights are switched on with a sensor but in Homeydash the lamp is off for example. After closing HomeyDash an restarting it the problem is solved. btw I don’t use the PI version.
What is a good solution for this problem? For example a (hidden) refresh button.
It already has a refresh button
Found!
Tnx for the tip.
Hi, before 2 month Homeydash stop working. I test another computer, another browser, and connection, again and again new connection and authorisation, but i still have blank page, only bottom button
where is a problem ? Maybe is any another dashboard. Thx
I use Homey PRO v4
You must re-add the token. I think it expires or so.
how i can do this ?
What do you mean? Just install the dashboard again, follow the first post if you forgot. Cheers
but i use online version
Then u are in the wrong topic. But this “issue “ u have is because of an incorrect token.
First of all; thanks for developing the dashboard and the manual to install it on a RPi.
It runs on a Pi3 with the iPad theme.
I’ve copied the code for the inside temperature section and converted it for a solar heater.
Just because I’m literally in front of the screen, I just want to have a quick look to check the solar temperature on the roof. That’s why it’s in the top left corner, permanently visible.
Once again, thanks!
I like this, thnx, going to try soon
First of all thanks for the dashboard. I’ve installed it on my rpi. It looks like this:
during the day:
in the evening and night:
The ‘buienradar’ does refresh but the camera doesn’t. This is the code:
index.html
<!-- scripts -->
<script type="text/javascript">
function ChangeMedia(){
    var d = new Date();
    var t = d.getTime();
    document.getElementById('image1').src = "https://api.buienradar.nl/image/1.0/RadarMapNL?w=140&h=140"+t;
    document.getElementById('image2').src = "http://192.168.1.73:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=*****&pwd=********"+t;
var reloadcam = setInterval(ChangeMedia, 1000);
</script>
<!-- HTML -->
<div id="device" class="device on" style="text-align:left;padding:0;">
	<a href="" target="popup" onclick="window.open('https://gadgets.buienradar.nl/gadget/zoommap/?lat=*********&lng=********&overname=2&zoom=8&naam=******&size=3&voor=1','popup','width=550,height=550'); return false;">
		<img src="https://api.buienradar.nl/image/1.0/RadarMapNL?w=140&h=140" id="image1" class="device" style="opacity: 100">
	</a>
</div>
	<a href="" id="image2" target="popup" onclick="window.open('http://192.168.1.73:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=******&pwd=********','popup','width=600,height=600'); return false;">
		<img src="http://192.168.1.73:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=******&pwd=********" id="image2" height="140" width="140" class="device" style="opacity: 100">
	</a>
</div>
good evening everyone
I followed the tutorial to the letter to install homeydash on a raspberry. BUT on the end of the installation I have this error:
ERROR: Cannot copy to clipboard: Command failed xsel --clipboard --input xsel: can’t open display: (null)
: inappropriate ioctl for device
Do you know what I could have missed?
thank you in advance
Am i right that the editable version of the dashboard here, isnt available on the nest hub (as the hub uses the online version?) Is it possible to run it locally somewhere and send it to the nest hub?
Yes that is possible as described in the first 2 posts of this very topic.
My bad. I’m a total noob when it comes to programming
When it’s too hard for u to run a server and fix some css files urself then i would suggest to use the online version. It comes with some restrictions ofc but it’s easy to use.
I have the online version, but I really miss the option to see temperatures, percentages, colors and stuff like that on the tiles. I ll try my best. Thanks so far! If i succeed, I ll make a small donation :+1:
Just hit and hold the tile and you can get any info on it that is supported (temperature, power, humidity…)
