Hi everyone,
I’m running into a strange issue with my Homey Energy Dongle and a phase-monitoring flow. Hopefully someone recognizes this.
My setup:
- Main connection: 3x 25A
- Measurement: Homey Energy Dongle (P1)
- EV Charger: Amina charger (charging the car at 3-phase, 16A per phase)
The issue:
I have a flow that warns me of an overload on phase 3:
- WHEN: Homey Energy Dongle - Load (phase 3) becomes greater than 90% for 30 seconds
- THEN: Send timeline and push notification
However, this flow keeps triggering at the exact moment the Amina charger finishes charging (when the car stops drawing power). At that same moment, I also get the built-in notification from the Energy Dongle itself: “the load on phase 3 has exceeded 90%”.
What I’ve already tried:
- Increased the duration in the WHEN card from 15 to 30 seconds.
- Added a Logic card in the AND column: first “Load (phase 3) is greater than 90” and later changed it to “Current (phase 3) is greater than 23”. Even with this check, the notification still triggers.
- Checked Homey Insights, but there’s no visible spike on the 24-hour graph (likely averaged out).
It seems like the Energy Dongle registers a brief spike when the charger disconnects, and the value gets “stuck” above the threshold for a bit before the 0A reading comes through.
Does anyone have an idea how to reliably filter out this brief switch-off spike or stuck value in my flow?
Hoi allemaal,
Ik loop tegen een vreemd probleem aan met mijn Homey Energy Dongle en een flow voor fase-bewaking. Hopelijk herkent iemand dit.
Mijn situatie:
- Hoofdaansluiting: 3x 25A
- Meting: Homey Energy Dongle (P1)
- Laadpaal: Amina lader (laadt de auto op 3-fase, 16A per fase)
Het probleem:
Ik heb een flow die me waarschuwt bij overbelasting op fase 3:
- ALS: Homey Energy Dongle - Belasting (fase 3) wordt meer dan 90% voor 30 seconden
- DAN: Stuur tijdlijn- en pushmelding
Deze flow gaat echter telkens af op het exacte moment dat de Amina lader klaar is met laden (en de auto dus stopt met stroom vragen). Op datzelfde moment krijg ik ook de ingebouwde melding van de Energy Dongle zelf: “de belasting op fase 3 heeft de 90% overschreden”.
Wat ik al geprobeerd heb:
- De tijd in de ALS-kaart verhoogd van 15 naar 30 seconden.
- In de EN-kolom een Logic-kaart toegevoegd: eerst “Belasting (fase 3) is groter dan 90” en daarna aangepast naar “Stroom (fase 3) is groter dan 23”. Ook dan blijft de melding komen.
- In Homey Insights gekeken, maar op de 24-uurs grafiek is geen piek zichtbaar (waarschijnlijk wordt die korte piek weggemiddeld).
Het lijkt erop dat de Energy Dongle bij het afschakelen van de lader een korte piek registreert en de waarde daarna even blijft “hangen” voordat de 0A-waarde doorkomt.
Heeft iemand een idee hoe ik deze korte uitschakelpiek of hangende waarde betrouwbaar kan wegfilteren in mijn flow?
