Hello
at the moment I have an internet failure and my lamps do not work in combination with the hue bridge
I have connected fibaro motion sensors and lamps through the hi bridge which communicates with Homey
both homey and the hi bridge work locally and should the lighting still be on?
Fibaro motion sensors use Z-Wave, so they can’t be connected to a Hue bridge (which is a Zigbee controller).
As for local support: the Hue API supports both local and remote access. To support Hue on Homey Cloud, the app needs to use remote access. I don’t know if that means that for Homey Pro it also uses remote access, though.
However, Homey Pro itself might also have issues with a missing internet connection, even if it tries to use the Hue bridge locally.
