Home / away 2nd iPhone
I was referring to the Smart Presence app. That is based on a fixed IP-address. See my earlier post.
Ah OK my mistake :blush: I was thinking reaction was on my last remark.
Hello Rob,
I use the Locative app for this https://locative.app
Works great and can make the range within 50 m. I had before always the problem the my daughter was with friends in the neighborhood and Homey thanked she was at hom. Not any more.
You have to make some changes butt works well.
You can find the way to install it in this forum if you search for Locative and iPhone.
You have to work with Homey webhooks.
Looks like a good solution. Unfortunately only IOS. For instructions there is also: Geofencing met Locative – Homey Cornelisse
Oh not Android. Good luck further
Hello. We have never had problems with presence with the iPhone, when we follow some basic rules. Applies to HP19 and HP23. Home/away must be switched on. Location, Homey app setting and system settings must be correct in iPhone. Mobile data must be switched on and last but not least, the Homey app must NOT be closed. And as long as you visit the Homey app regularly, everything works as it should. (And we have no VPN client in use). I have also played with the smart presence app, that also works fine, but I don’t need it since builtin work great.
Problem solved!
I contacted Homey support.
After checking all the settings and re-installing the Homeyapp, nothing changed.
But then I was asked to go to:
“more” and click on my Homey at the top and select my Homey again…
After that home /away worked for the first time!
Thanks to everyone who was thinking with me and to Homey Support!
I got the same problem. But it works on my wifes phone, but not mine.
I found out what to do, if anyone else got the problem.
Try to tap the right buttom corner “more” - - - > then select your homey just under your account name - - - > then click on your homey, this worked for me.
I have the same problem, in my case the homey built-in home/away is also not working. I only give the permission, that the homey app can read the location data “always” and then it should work? Is it right?
