Ok, I was able to gather the logs. This is the full flow
- On / off triggered:
2025-08-15T08:40:17.108Z [log] [ManagerDrivers] [Driver:rgb_led_strip_controller] [Device:174731e7-fbc9-4428-8498-d8b99a49decb] changeOnOff() → false zigbee-clusters:cluster ep: 1, cl: onOff (6) send frame ZCLStandardHeader { frameControl: [ 'clusterSpecific' ], data: <Buffer >, cmdId: 0, trxSequenceNumber: 67 } +6s zigbee-clusters:cluster ep: 1, cl: onOff (6) received frame defaultResponse onOff.defaultResponse { cmdId: 0, status: 'SUCCESS' } +95ms
2025-08-15T08:40:23.168Z [log] [ManagerDrivers] [Driver:rgb_led_strip_controller] [Device:174731e7-fbc9-4428-8498-d8b99a49decb] changeOnOff() → true zigbee-clusters:cluster ep: 1, cl: onOff (6) send frame ZCLStandardHeader { frameControl: [ 'clusterSpecific' ], data: <Buffer >, cmdId: 1, trxSequenceNumber: 68 } +6s zigbee-clusters:cluster ep: 1, cl: onOff (6) received frame defaultResponse onOff.defaultResponse { cmdId: 1, status: 'SUCCESS' } +90ms zigbee-clusters:cluster ep: 1, cl: levelControl (8) read attributes [ 0 ] +1s zigbee-clusters:cluster ep: 1, cl: levelControl (8) send frame ZCLStandardHeader { frameControl: [], data: levelControl.readAttributes { attributes: [ 0 ] }, cmdId: 0, trxSequenceNumber: 45 } +0ms zigbee-clusters:cluster ep: 1, cl: levelControl (8) received frame readAttributesStructured.response levelControl.readAttributesStructured.response { attributes: <Buffer 00 00 00 20 24> } +102ms zigbee-clusters:cluster ep: 1, cl: levelControl (8) read attributes result { attributes: <Buffer 00 00 00 20 24> } +1ms
Result: No issues
- Dim triggered - freeze
2025-08-15T08:41:18.152Z [log] [ManagerDrivers] [Driver:rgb_led_strip_controller] [Device:174731e7-fbc9-4428-8498-d8b99a49decb] changeDimLevel() → 0.83
data: levelControl.moveToLevelWithOnOff {
level: 211,
transitionTime: 65535
cmdId: 4,
trxSequenceNumber: 47
} +7s
zigbee-clusters:cluster ep: 1, cl: levelControl (8) received frame defaultResponse levelControl.defaultResponse { cmdId: 4, status: 'SUCCESS' } +78ms
zigbee-clusters:cluster ep: 1, cl: levelControl (8) received frame reportAttributes levelControl.reportAttributes { attributes: <Buffer 00 00 20 d3> } +188ms
- Off command - no response on Led
2025-08-15T08:41:42.974Z [log] [ManagerDrivers] [Driver:rgb_led_strip_controller] [Device:174731e7-fbc9-4428-8498-d8b99a49decb] changeOnOff() → false
data: <Buffer >,
cmdId: 0,
trxSequenceNumber: 71
} +7s
zigbee-clusters:cluster ep: 1, cl: onOff (6) received frame defaultResponse onOff.defaultResponse { cmdId: 0, status: 'SUCCESS' } +104ms
zigbee-clusters:cluster ep: 1, cl: onOff (6) received frame reportAttributes onOff.reportAttributes { attributes: <Buffer 00 00 10 00> } +363ms
Interesingly, it reports success in logs..
