sorry for posting av novice question.
Need a flow that controls my water heater the first of every month it should heat it to 75 C.
someting like this:
will this work ?
That will turn on the heater for the entire week, which I don’t think is your intention.
If you know how long it will take to heat the heater up to 75°C (say 2 hours), you can turn it on and under “Then” add a card to turn it off with a delay of 2 hours. Otherwise, you need to periodically check if the temperature has reached 75°C and turn it off when it has.
ok thx…
back to the drawing board…
But note! After homey reboot (ptp, update, flow, unplanned, etc.) the delay doesn’t work anymore!
I would recommend to work with the Countdown App because the countdown is still alive after a reboot.
What sensor do you use (qubino?)
I use HeatIT z-relay
