Have a camera stream in my dashboard
I have 7 Dahua camera’s and a NVR.
I have access to the direct RTSP sources like: rtsp://admin:admin@10.7.6.67:554/cam/realmonitor?channel=1&subtype=0
Can I create 7 tiles with all the channel or does someone allready have this working. With the imou app on my iphone I am able to connect and see the movement triggers.
Maybe some has done this for HOMEY PRO (2023) as well.
BR
Maybe it is possible when you use a dasbord like this and add 7 cams with the streams.
I don’t use this so have no idea if it works.
@Paul_Vogels, did you get it to work?
Afaik Homey cannot show streams. It can show snapshots though, so when you use the Dashboards app like @Mike1233 proposed, you can emulate a ‘stream’ a bit:
So, if I want my wall-mount tablet to show who is at the door in a stream, and potentially answer the doorbell, I need a different app …
Yes.
With Homey it’s limited to view snapshots, and to open the door as far as I know, no speaking/listening.
Take a look at the flowcards of two doorbell apps f.e.
Hello Peter,
where did you find this menu? i have snapshot of a camera in my dashboard and i would like to update it every 10 mins. Or when movement is detected.
It"s in the device properties of the Dashboards app by Marcus Skogsaas.
Not related to Homey dashboard.
Aah, thanks!
