Gira Senic switch connection to Homey
Hi
is it possible to connect a Gira Senic wall switch (Friends of Hue) to Homey?
I do not own a Hue Bridge
If so, how do I set this up?
If not, is it possible to make such a connection/compatibility?
Maybe this app (hue without the bridge)
I don’t think it will be able to work with my app… the friends of Hue devices do not follow the same specs as the Hue device does.
@Charl can you add it as a generic device and interview it for me?
You won’t even be able to add it to Homey.
The FoH switch does not want to connect to a Zigbee controller (according to the Zigbee specification) and is using only 4 Zigbee channels.
The latter can be resolved by changing the Zigbee channel of your Homey; but you have to reconfigure the entire network.
Thank you all for your replys!
I have returned the Gira FOH switches and bought a fibero 2 dimmer instead.
So @johan_bendz I can’t add it anymore.
Thanks again for your help
is there any news regarding friends of hue with homey?
I have a lot of the Senic switches and a hue bridge. I want to change my whole system to homey now.
Do you think there is a possibility in the future to add the senic Gira switches to homey?
With or without the hue bridge doesn’t matter as long as I can use them in homey.
Thank you
