I’ve just set up advanced charging on my Tab11 Plus using a smart plug via Tasker and a webhook to inform Homey of the battery level. However, after installing Fully with remote access enabled, I noticed that it also reports the battery level, which makes my Tasker setup redundant. Do you also use the battery level provided by Fully, and does it work reliably?
Hi!
I have it setup since a couple of months in this way using the battery reported from Fully. I have a Galaxy Tab 9+ and in an advanced flow use the battery reported from the Fully device to turn on the smart plug when reported battery drops below 20% and turn off the plug when the battery gets above 80%. It’s been working reliably since then.
Just a tip. Your samsung tablet has a built-in function for this purpose, thats stops charging at a point of your choice (80% recommended) and runs the device directly on external power. This option is way better for both safety and your battery. It’s like using a device without a battery at all. Only when you disconnect the device it starts using the battey.
Your method is good for older tablets or phones that don’t have this function. But it still gives your battery many cycles of charging and discharging, and that will damage the battery over time.
Thanks for the tip @Torbjorn_Melbye. I actually used that built-in option for a while set to 80%. In my case it didn’t seem to use electricity from the connected USB-C-cable (always connected). Since it still used battery, eventhough wired, whenever the battery percentage dropped just a couple of percent it started charging again up to 80%, resulting in several charging cycles per day. But I think I will have a second try how that works out.
Hi!
I know its a long time ago you replied on this topic, But I just recently am using my Samsung Tablet with Fully Kiosk and also facing some issues that my tablet is turning on by itself (because of the camera) Can you show me your settings in Fully Kiosk Browser (Maybe via PB?)
Also interested @Peter_Kawa & @Niclas on your Fully config and how you enumerate battery via homey? Assume maybe MQTT??
I am currently using HA (with Fully integration) and publishing the battery from HA back to Homey then have an Advanced flow set for 80/20 to stop and start direct connected Shelly. I am trying to remove reliance on HA where I can, but it works fine.
In other news, I still get maybe a Fully Single App (just displaying Homey Dashboard) hang once a month with blank screen. Still investigating.
Hi @PJ-AU
I’m using the Homey App Dashboard Controller.
An alternative option would be to use Tasker and webhooks.
Thanks @Niclas, woohoo I didn’t realize this also worked with Fully Single App as well!
I have also have 2 x Samsung Galaxy Tab A9+ (SM-X210) tablets (8GB RAM) running Homey 9.6.X and launched with using Fully Single App for running Dashboards.
Generally speaking it works well and looks great, however after a few days of operation, clicking on objects eventually becomes unresponsive (even simple buttons to turn off a light). I thought this maybe the wifi network, however have spent a bunch of time to optimise (including uplifting to 5Ghz) this and even though it does work better, the user experience still becomes slow.
In the release notes for 9.7 Homey App (yet to be released on Google Play Store) it mentions “Faster and more future-proof: The Homey app now runs on a new internal architecture, resulting in improved performance, smoother interactions, and a more stable foundation for future features.” I am hopeful that this may improve things, but wondered if anyone else experiences the same UX issues (especially with Fully Single App)? Homey - Android App version 9.7 - #9 by Lukasz_Kostek suggests no improvements after 9.7 upgrade, but perhaps this might be just for him.
I was considering testing without Fully Single App for a week to see if the Homey app stand-alone works better. However really rely on Fully App for remote control and battery monitoring which have been very valuable.
Thanks
I am finding 9.7.1 much more responsive after a few days than previous releases, however early days.
Fast forward a few months …
Mobile App 9.8 release was decent but still it becomes unresponsive after a few days for me, however after clicking for a while it comes back to life, however in a perfect world i just want to leave it to run without any ongoing maintenance, especially given these tablets only run Homey app as dedicated Dashboard.
To try and further isolate this hanging issue, reluctantly I have since disabled Fully Single App, however the problem continues to occur after a few days. I have a new symptom with 9.9 release where when the Dashboard becomes sluggish, any light buttons I have don’t change colour with yellow light icon when pressed. I have to restart the app - which is something I am contemplating automating daily (somehow).
I have 2 x Samsung A9+ with 8GB RAM (approx. 4GB resident) with reliable 5GHz connectivity and nothing else running (outside OOTB Samsung background tasks) except Homey (previously with Fully) and they both do it. I have also now switched Homey app to ignore battery events thinking it might be a sleep type scenario, but no luck. Also testing pinning Homey app.
Anyone experiencing this issue on Android with or with or without Fully, otherwise I might raise support case as I am running out of ideas.
Thanks all.
Hi everyone, newbie here so was hoping to get any advice from experts like yourselves. I am running a Homey dashboard through Fully Kiosk Plus on an android tablet. I have locked down the dashboard through the single kiosk mode but I’d also quite like to use other apps on the tablet. The tablet turns on using the motion detection function within Fully Kiosk. I’m trying to think of a way of the kiosk opening on the dashboard in Homey but then still allowing me to open other apps on the tablet ? Any suggestions from you clever people ?
Thanks, Nathan
