Flows does not start anymore from Fibaro s2
About three weeks ago, flow activation from all my Fibaro dimmer 2 S2 input stopped working. The same thing also happend to my Namron 4 way switch. Activating the flows from the apps works fine.
Tried to reset both homey and fibaro app. Tried to remove and add again one of the fibaro dimmer 2. Scene activation is still active in the settings of the dimmer 2. This has worked fine for about 3 years, so this was very strange.
Any suggestions?
Which firmware is installed on your Homey Pro? And which Homey Pro model do you have?
Homey Pro Early 2023 model
Firmware 13.2.0-rc.5
Hmm, in that case, unfortunately I can’t help you.
The issue with Scene Activation started with the experimental firmware version v13.2.0-rc.1/2:
[bug?] all multi-click-activated flows no longer working
[APP] Fibaro - Your home is your castle (by Athom) - #1077 by 0burner0
However, the problem was actually resolved with version v13.2.0-rc.5, at least for me and other users:
[APP] Fibaro - Your home is your castle (by Athom) - #1092 by DirkG
The only thing I can recommend is to contact Athom’s support team.
