Flow to use brightness sensor in Aqara Motion Sensor?
I am a bit disapointed that I have to ask this question here as I thought it would be easy and I use Homey now for a few weeks but I am not able to use the brightness sensor of an Aqara Motion Sensor in a flow.
I want to switch on/off lights when there is motion but only if the Lux level is below a certain value. Unfortunately I cant find in the “if” and “and” Section of the flow any reference to the Lux level.
I thought it would be as easy as " if motion" and “Lux < 10” then “switch lights on”. But seems not the case and I couldnt find the answer in the forum here either.
Thanks for any hint.
Kind Regards,
Uli
Maybe this can help.
Thanks a lot ! This indeed helps ! In the tags the motion sensors “brightness” appear and can be used in the “AND” Section.
Thanks again. I havent had experience yet using tags.
Regards;
Uli
@Capetrip can you please share your flow?
I can`t seem to figure this one out.
I want a light to turn on when motion is registered and the lux-value is below 60.
I tried to read the post “How to use tags in a flow” but can`t make much of it.
A flow-example would be very appreciated
Regards,
Morten Christensen
