I have an AQARA light sensor that I want to introduce into a flow, but in the flow cards that I can select, it only says “when the brightness becomes less than” or “when the brightness becomes greater than”. But with these flow cards, if the brightness does not change, the flow does not work. How can I make it so that when the brightness is less than a value or greater than a value? the flow works. category is created to show, and explain the working of specific Flows in homey.
You will probably be able to specify the exact brightness value (or greater than/less than) in an AND card. This would mean that you have to use a different trigger/WHEN card. For instance a time trigger (e.g. every minute as the WHEN card).
If I change the brightness manually, when changing state it works.
As a trigger in When you use “The luminance changed”
In And you use a logic card, text/number (choose luminance) becomes less (or greater) than your value then trigger your actions action.
Your screenshot shows the WHEN cards. Most likely you’ll see different cards when you try to add an AND card.
If there is no AND card to specify the luminance value, then you also have the option to use a logic card to compare the luminance value tag of the sensor with the threshold you want.
EDIT: didn’t see JonasW’s above post, with the same answer. ![]()
Please could you show me an example that I could refer to
thanks
It works for me now, the flow in the logic section does show me the options “GREATER THAN” and “LESS THAN”.
THANKS
Hello, this flow, as I said, works perfectly for me, but I am now trying to make a similar one and when I use the “AND” card and the “LOGICA” card when entering the Lux value, the program crashes and does not let me continue. Why does it not let me use the luminance now through the “LOGICA” card? Do I have to configure something or has the operation changed?
The strange thing is that if I copy the “LOGICA” card “Y” from the flow that works in the new flow, it doesn’t give me an error, but if I make a new one, it does give an error.
