Flow to check what Sonos is playing
I am trying create a flow to see if my Sonos is streaming a (specific) radio station.
But so far I’ve not been able to make it work.
What have I tried:
  • every 1 hour
  • AND check if Sonos Device Is playing
  • AND check if Sonos [Tag] equals/contains [MyRadioStation]
    I tried to add a Logic check to see if a stream contains something to determine if its a Internet Radio/URL/Stream, and not a local mp3/flac file
Here comes the trouble:
Sonos (or the Homey Sonos app) does not seem to state what if (or what) Internet Radio Station is Streaming.
Only when you play a song you can check Album, Artist, Track info.
BUT - I thought to be smart and check for Album, Artist, Track info. So if the Sonos is playing AND there is Album, Artist, Track info - it probably will be NOT be streaming a Radio station. But alas, it seems that if you have played a local track (something in your Sonos Queue), followed by starting a Radio/TuneIn stream, the Album, Artist, Track variables are still filled with the information of last track played.
I also tried the The Hidden Sonos Web Interface and see if I can use a HTTP GET to compare with a variable. But can find anything useful.
Does anyone know a way to solve this / Can someone try figuring out a way fixing this?
I have the same issue.
Is there a fix ?
Does anyone have solved this problem or have an idea where to start to fix this issue?
Any suggestion is appreciated.
If you need more information please tell.
Issue a bug report with the developer? In this case Athom?
I hoped for a different solution or workaround. But since no-one seems to know how … I’ve filled in a support request.
To be continued …
Any response on your request elfrigo?
Maybe you can do something with HTTP request, there is a topic (in Dutch but google translate is your friend) Sonos status via HTTP request
A solution in german, deepl is your friend.
