Fibaro Walli, do they work with Homey?
With Homey Firmware: 3.2.1-rc.2 it is possible (again) to add the Fibaro Walli Dimmer.
I have added 2 Walli dimmers.
Hi there
I spent lot of time reading this topic and some other, I got 2 Walli Roller Shutter ans something isn’t clear for me. Got plenty of questions
Got Fibaro App V2.2.8 (seen under app details)
I can’t see Walli Roller Shutter into when I try to add from my IPhone Homey App, but from my MAC and Web app looks like I can add them but it"s indicated deprecated and in grey.
So my question, is wha’t the “official” way to add them ? Adding as “roller shutter” for me this option if for old roller shutter (V1.6) FGR221 (and I have some in my home)
When talking about fibaro app github we agree we’re talking about this version
As I played with alpha branch I’m in doubt of what’s this latest official
I installed the branch alpha and says version 2.2.8
git clone -b alpha https://github.com/athombv/com.fibaro/
cd com.fibaro/
homey app install
Then I switched back to the branch master and says version 2.2.8 also, so I’m totally lost and looks like on github version master says 'in file app.json version 2.1.31
cd ..
rm -rf com.fibaro/
git clone https://github.com/athombv/com.fibaro/
homey app install
And also master branch latest release says 2.1.28, so how it’s possible CLI install master branch and homey says fibaro version is 2.2.8? I also removed the fibaro app from my smartphone, and installed back, always says 2.2.8.
thanks for any idea of what’s going on
Actually it doesnt matter which device you install it with, as long as it’s from same app, this case fibaro. It will automaticly install correct driver whereas it looks for productid . Walli rollershutter just installs as rollershutter.
Current Branche Alpha is 2.2.8. This one seems to be in the AppStore.
Current branche Master Is 2.1.31
@Da_JoJo
Makes sense, In fact it recognize device with it’s “product ID”, that’s good to know. thanks
vraagje, als je alleen de FIBARO WALLI DIMMER
FGWDEU-111 hebt en geen home center van Fibaro maar alleen de homey, kun je hem dan werkend krijgen ?
Have a look at the Fibaro App.
heb ik gedaan maar kom niet verder dan
en op de pc idem dito
Lijkt erop dat er geen Homey is gekoppeld aan het account waarmee je in de App Store kijkt.
Gaat prima met de Homey Fibaro app.
Jazeker! Ik heb ook alleen een Homey en heb de Walli’s gewoon toegevoegd. In de eerste versies van de app ging dat niet altijd goed maar sinds een maand of 5 gaat dat probleemloos.
Top, dan weet ik wat ik ga doen.
Mvg Mark van der Maazen.
Verzonden vanaf mijn smartphone.
-------- Oorspronkelijk bericht --------
Hello I’ve got walli roller shutter and it seems to not work properly with my blinds. It’s able only to go up and down, I’m not able to set position. I tried all branches, even newest with sdk3
 After copying code and creating my own dev app, changing setting to venetian blinds I was able to get tilting work atleast to open and closed. I’ve seen comments “Multichannel nodes don’t work properly with secureInclusion due to Fibaro firmware issues” not sure if this applies also for roller shutter.
I had qubino roller shutter and after few days I was able to somehow get it work in venetian mode. I tried to compare apps and how they are handling blinds and it seems to be pretty easy. So I’m not sure if there is a problem with fibaro firmware or how homey is communicating with it. May be if someone could point me in right direction I would be really grateful. Thanks
I have the Fibaro Walli Dimmer. It seems to work almost completely, only it doesn’t dim.
So when I dim in the app, nothing happens. When I long press the bottom button, nothing happens.
Has this dimmer ever worked for anyone?
It is the FGWDEU-111
The original Question:
Guess what
 At first the dimmer did not work. On its own, light would turn on, and sometimes off. Removed it, paired it again, and guess what, it worked
Strange.
@Hans_Maarten_Vink @Ronald_Otto
If you could please keep the conversation in English as much as possible, then more people will be able to participate and help you. If you would rather not or can’t communicate in English then please check out Non-English boards/categories.
Please translate your post.
Good to hear. Now i can order more of them. And that my experiance was just a glitch in the Matrix.
They are bueatifull
