Fibaro Smart Implant
As I mentioned already, I guess the behavior of the device tile has absolutely nothing todo with the settings of the outputs of the SI. In theory, the push on the device tile is more or less an input action to switch the output of the SI. Hope you understand what I mean.
Which Homey firmware version do you use?
The v11.1.0, which was released two days ago, includes some bug fixes acc. button capabilities:
– Fixes an issue with certain button capabilities that could cause the button not to work as expected (e.g. muting the volume).
– Fixes an issue where setting uiComponent to null would not work.
I’m not sure, if this is related to your problem, but it might be worth a try.
Which Homey App version do you use?
Is this behavior present on different smartphones/tablets?
Further suggestions:
– Restart the Fibaro App
– Re-install the Fibaro App without deleting it before
– Restart HP23
– PTP HP23
– Exclude and re-include the SI (I know, that sucks! But @martijnpoppen made a script to fix all the flows after excluding and re-including devices → [HOW-TO][Pro][Cloud] - Tool to FIX (advanced) flows after removing and re-adding devices)
— Contact Athom support
