Hey,
I have a Fibaro smart implant.
A Panasonic heat pump is connected to this, when it gets too cold outside and it is no longer profitable, it gives a signal.
I receive that signal with the Smart Implant. From that moment I start the oil boiler.
But if the signal drops, I should also be able to give a stop message to a flow. But I can’t give that signal.
Because I can only choose Input 1 switched. So there is no option for input 1 not switched.
Is there anyone who might know a solution to this?
I think you need to use the first two? The “switched” sounds like it means “toggled” (either opened or closed).
I tought that also, So I tried that, but nothing happend.
Maybe I did something wrong ? Are you sure about that ?
No, I’m not sure (although I just noticed that my post was showing Input 2 instead of Input 1, but I assume that you picked the correct one).
If the “Input 1 switched” flow trigger works for you, you can probably use an AND card to determine what the new state is, and use that to switch your boiler on/off.
You were correct. Problem was that it takes very long for the pump when to make a change.
It’s all working now.
Thanks!
