Fibaro roller shutter 3 only opening and closing 0 or 100%
Hi all,
This weekend I received the new Homey Pro. I used to have the Homey Bridge but due to a mistake I had to decide to start all over again with the new Homey Pro. :sweat_smile:
I use the Fibaro Roller Shutter 3 to control my roller shutters. This used to work fine in the previous setup, but since I use the Homey Pro I have the problem that I can only open or close the roller shutter fully (0 or 100%). Any inbetween mode will be ignored. How can I solve this problem?
Kind regards,
Marieke
Have you recalibrated the RS3?
@fantross Thank you! That fixed the problem! I was not sure of recalibrating at first, as I was afraid that would not work properly yet with the new Homey. But I did and everything works fine by now. Thanks!
Please use the Fibaro main topic for problems with Fibaro devices or the Homey Fibaro app:
[APP] Fibaro - Your home is your castle (by Athom)
For this reason this topic has been closed.
