Problem with Fibaro Roller Shutter 3?
I use a Fibaro Roller Shutter 3 with my Homey Pro and everything was working fine.
Suddenly, my shutter does not work anymore, neither with the application nor with the physical switches on the wall.
By checking homey in developer mode, my fibaro micro module is well detected, the connection test is correct, I tried a heal which did not return an error message.
When I activate the command with my app I hear the “click” of the micromodule in the wall.
Do you think we can exclude a problem related to the micro-module / homey or not?
Thanks for your advice!
