I have a FGK-106 (door window sensor 1 with attached DS18B20 temp sensor)
I have 2 problems
Tamper alarm is always triggered (seems like a common issue?)
It wont report the temperature.
What I have done so far
Removed the device from Settings ->Z-wave
Included the device again
Did not work
Removed the device
Reset the device physically
Rebooted homey
Added the device again
This didnt work either.
Contact alarm works great but no temp and tampered is always triggered.
I have looked into the advanced settings but I cannot find anything related to reporting the temp to homey.
Homey version 2.1.2
Model Early 2016.
Caseda
June 3, 2019, 8:12pm
#2
for the temperature:
as for the tamper alarm, make sure both switches are properly pressed, the foam adhesive on the back is pretty known for not pressing the back switch properly, especially when it gets old. (re-use is not possible at all, even though it sticks, it will not press the button anymore)
I will try the fix, just figure out how to install it since Im not the CLI-Pro
If I hear a “click” on both tamper buttons they should be okay, shouldnt they?
I have installed your alpha version from github, I can now confirm that this works. Thanks alot!
The tampering error is still there though, but I can live with that since Im only using it for the pool.
Keep up the good work!
