Hello, I would like to connect my fan/lamp wich should be based on a bt 2.4g connection.
Is it possible to develop some support for it?
Our crystal balls are broken today, so you have to provide a bit more informationā¦
mine is melted ![]()
Iām really sorry for your laps. Hope you can fix it as soon as possible ![]()
About my lamp is the following
https://m.it.aliexpress.com/item/1005004330055100.html
This one is the control part. As far I know it work via Bluetooth (at least the app that comes with the lamp, no need to pair it)
This are all the data I know.
If there are any others I can tell you, just let me know ![]()
Thatās not enough for a developer to even consider creating support for it, Iām afraid.
Could you tell me please what other data you need. So I can try to find them
All the GATT services and characteristics the device uses, how itās discovered, how to pair with it.
But just to be clear, Iām not offering to write an app for it.
Does the app have IFTTT support? If so you can make webhooks to trigger it with Homey
If I understand correctly, you have an app for this lamp on your phone? Downloaded from playstore (assuming your phone runs Android)? If so, please tell us which app you are using and we can take a quick look.
Donāt worry no such expectations ![]()
Iām from the āRTFMā generation, but is long time I donāt code anymore. But if you can address me in the right direction is good ![]()
No it has not ![]()
Thank you, I will try
Thank you , Iāve already started to read it ![]()
Any luck with controlling this fan with homey?
I wonder if a solution lies in buying a cheap esp32 device or a shelly smart plug and then using something like this guy did for Home Assistant:
What does a smart plug have to do with a ceiling fan? Usually those are controlled via switches, not plugged in to the power outlet.
That one has an ESP32 chip inside with BLE bluetooth inside which could be flashed with a custom version of ESPHome and then the potentially linked to Homey with the ESPHome Controller | Homey app. As far as I know this kind of ceiling fan uses BLE advertising rather than a specific bluetooth pairing, so the Shelly smart plug could be used to braadcast the fan commands using BLE advertising
