Fahrenheit Rounding to Whole Degrees
Is there a way to configure Homey to not round Celsius-to-Fahrenheit conversions to the nearest whole degree? I’m using temperature sensors that report at a resolution of 0.1°C, which would be about 0.2°F (0.18°F to be precise). The rounding also affects the insights graphs.
I’m not expecting my sensors to be absolutely accurate to 0.1°C, but I do want to see relative movement at that resolution.
Thanks
Mark
Does the app for your specific device report in 0.1 degree when Homey is in Celsius mode / location?
Or is it just this app always roundig to full digits?
In that case you need to contact the App developer
Thanks for the reply. As an experiment, I switched my locale to Canada to see Celsius and this is what I saw:
Switching back to my U.S. locale, the same sensors appeared this way:
I also wanted to add that the issue shows very clearly when looking at insights on a specific temperature sensor.
Temperature insights when Homey Pro is using Celsius:
Temperature insights when Homey Pro is using Fahrenheit:
Have you reported your issue to Athom support?
