Everything Presence One?
Hey Guys
Wondering with the Everything Smart app can that be used with Everything Presence One sensor directly to homey without using Home Assistant or any other device
Hi John!
Ask the guy who built it I would say?
There’s a very clear support link on the app store page you linked to.
(Look foor: Need help … ask developer …)
Thanks - ye I thought about that but was wondering if anyone had used the app with the device
I would like to know if anyone knows how to set this device up? The instructions from EP1 is for smarting’s, and home assistant, so, I do not know how to do the initial firmware update nor the Wi-Fi setup. Dose anyone have any insight on this? Any help would be greatly appreciated! :slight_smile:
Try looking here [APP][Pro] HomeKit Controller - for a better Homey
No that did not help, but I was able to figure it out.
What I was having a problem with was I did not know how to get to the Wi-Fi portion of the device so I could add my Wi-Fi information, but I was able to figure that out. You have to go Everything Presence website and act as if you are going to add it to Home Assistant and just stop the process after you finish the Wi-Fi configuration, you can then install this app, it will now connect and the app will find the sensor.
Paired the sensor thanks to your instructions :grinning:
So you you still need home asistant to do it ?
This did not work for me, I even tried with SmartThings as I also have a SmartThings hub and it didn’t work with that either!
When you say “you can then install this app” you mean the Everything Smart app right?
as in this app? Everything Smart App for Homey | Homey
I have that app, I did everything you did, but it still wouldn’t connect to my Homey
