Dreo Heater
Hi
I have a Dreo heater whole room 360 in my garden den. I would like to be able to heat the room to avoid condensation during the winter month. I have an Aqaua humdity - temperature sensor up and running. However the Dreo app does not appear to support heaters. Is there any work round for this to be able to trun on the heater with a flow set around temp and humididty?
Thanks
Andy
I have raised this lack of devices support for their official app numerous times with Dreo themselves, to no avail.
At present I am using Amazon Alexa routines (which does work for all Dreo devices, fans, air purifiers, dehumidifier, fan heater, that I have). Then I have the Homey Amazon Echo community app run the Alexa routines to turn on, off, increase or decrease the fan speed, depending upon the Aqara sensors input from that room.
It’s not exactly the elegant integration solution I had hoped for when I spent a boatload of money on Homey Pro and Dreo devices, but it works okay.
Hi thanks for the reply a am just getting used to working with Homey have not used Amazon Alex routines so i guess i need to do a little research. Could you share an image of how you flow looks that me help me
Andy
Hi Andy
From one Andy to another, of course… just please don’t judge my crazy logic :rofl: You probably won’t need a good chunk of this, home automation is very much personal preference, but hopefully it might give you some ideas to get started.
It’s 2 Advanced Flows, the first mostly handles when to do stuff, and some odd simple devices.
The second is specifically for the air purifiers (using the Advanced Triggers app, that WHEN trigger card appears in a number of flows for lights, A/V system, an Android tablet running Dashboards etc that all run from that single call in the first Flow)
The Alexa routines are basic When say command (so it still works for voice control) turn on the device and set it to this mode. This Flow just runs the Routine manually like if you tapped the little play button in the Alexa mobile app.
Drop me a message if you need any help deciphering my flow craziness :rofl:
Thanks so much for this will take a look at it Wednesday as out tomorrow
Br
Andy
Thanks for the help i manage to sort it first time i have used Alexa to control within Homey
