Hello Community,
I have a question, I need to control a dumb heater with an aqara temperature sensor.
In home Assistant there is the thermostat function that can function in this way.
Is there a thermostat in Homey Pro or do I need to back out the aqara sensor and outlet to Home assistant? I’m hoping to migrate as much as possible to Homey as I like the flows much more.
Although they seem to be very limiting.
Thanks in advance.
If you can turn on/off your heater with Homey.
For instance with a power plug.
And you have an Aqara temperature sensor that works with Homey.
You can make flows to turn on or of, your heater with Homey.
Or just use vthermo, than you don’t need flows😇
