[APP][Pro] DREO (Community): Dreo fans, heaters, air purifiers, humidifiers and air conditioners in Homey
:wind_face: DREO (Community) puts your Dreo devices in Homey: switch them on and off, pick the mode and speed, set the temperature or humidity, and use all of it in Flows and on your dashboard. It logs in with your Dreo account, the same way the Dreo app on your phone does, and what you change in the Dreo app or on the device shows up in Homey straight away.
Dreo has an official Homey app as well, but it covers four device types and hasn’t been updated in months.
Free, no subscription, no server of my own. In English, Dutch, German, French, Italian, Spanish, Swedish, Norwegian and Danish.
:test_tube: Test version: https://homey.app/a/be.dreocommunity/test/
:mobile_phone_with_arrow: App Store: https://homey.app/a/be.dreocommunity/
My other apps
  • :package: Parcel Tracker: every parcel from 132 carriers, without carrier accounts
  • :pill: Medication Reminder: reminders until the medication is taken, stock tracking and reports
  • :automobile: MG iSMART: battery, range, charging and climate of your MG in Homey
  • :sun: PV Forecast: solar forecast that measures your roof and learns from your panels
  • :robot: MCP AI Bridge: control Homey with any AI assistant
  • :recycling_symbol: Recycle België: Belgian waste collection calendar
:house: Which devices
Nine device types, each with its own driver:
  • Tower fans (DR-HTF)
  • Air circulators, the TurboPoly fans (DR-HAF, DR-HPF)
  • Ceiling fans, fan and light (DR-HCF)
  • Evaporative coolers and misting fans (DR-HEC)
  • Air purifiers (DR-HAP)
  • Space heaters and wall heaters (DR-HSH, WH)
  • Portable air conditioners (DR-HAC)
  • Humidifiers (DR-HHM)
  • Dehumidifiers (DR-HDH)
That is 69 known models plus newer models in the same series. Every device only gets the controls it actually reports, so a heater without oscillation won’t show an oscillation switch.
A word of honesty: I don’t own a Dreo device. Everything is built from the hass-dreo code and checked against it, and the first user is now running it with ten devices, but many models haven’t been tried yet. If your device shows something that doesn’t match the Dreo app, or a button doesn’t do what it says, post it here with the model number. The model number is on the label of the device and in the device settings in Homey.
:key: Adding a device
  1. In Homey: Devices, +, DREO (Community), and pick the type of device.
  2. Log in with the e-mail address and password of your Dreo account. Leave the region on “Find out by itself” unless you know better.
  3. Pick the devices you want to add.
Devices someone shared with you in the Dreo app show up as well. If your account has a model the app doesn’t know yet, the pairing screen says which one, so you can post it here.
:sparkles: What it does
:bar_chart: On the device
Depending on the model:
  • Fans: power, mode, fan speed, oscillation and oscillation angle. On circulators also how far the head swings left, right, up and down, a fixed direction for the head, horizontal and vertical, the brightness, colour and effect of the ambient light, and arrows that turn the head a step. Circulators with a body sensor add follow me, the number of people they see and a presence alarm. Misting fans get their mist as a separate switch.
  • Heaters: heat level, target temperature, heating mode (heat, eco, fan only), airflow direction, temperature correction, and whether it is heating right now.
  • Air conditioners: cool, dry, fan, sleep and eco, with target temperature, fan speed and swing, whether the target temperature is reached, and hours of use.
  • Humidifiers, coolers and dehumidifiers: target humidity, mist level, the humidify switch, an empty tank on humidifiers and a full tank on dehumidifiers, and where the device reports it: water level, filter life, hours of use, auto mode, and whether the target humidity is reached.
  • Air purifiers: mode, fan speed, PM2.5 and filter life, a Purification switch where the purifier has one, and on the DR-HAP003S Standard or Soft for the auto mode.
  • Ceiling fans: the main light with brightness and colour temperature, and the ambient light with its brightness, colour and effect.
  • On most devices: display (on fans with automatic brightness, on newer heaters as off, on or automatic), panel sound, child lock, open window detection, temperature and humidity.
  • Presets on every device: save what the device does now under a name, for example “Sofa” or “Two people”, and bring it back with one tap in the widget or from a flow.
:high_voltage: Flow cards
468 cards over the nine device types. Every setting gets its own cards, so the list on your device follows what it can do.
Triggers
  • A setting was turned on or off (oscillation, display, child lock, light and so on)
  • Mode, fan speed, heat level or another setting changed, or changed to a value you pick
  • Temperature, humidity, PM2.5 or filter life changed
  • Water tank ran empty / was filled (humidifiers and coolers)
  • Water tank is full / was emptied (dehumidifiers)
  • Started heating / stopped heating
  • Someone came in front of the circulator / nobody anymore
  • Target temperature or humidity was reached
  • Device went offline / came back online
Conditions
  • A setting is on, or a mode is a value you pick
  • Temperature, humidity, PM2.5, filter life or another value is above …
  • Water tank is empty / full
  • Heater is heating
  • Someone is in front of the circulator
  • Device is online
Actions
  • Set every setting: mode, fan speed, oscillation and its angle, swing limits, a fixed head direction, heat level, target temperature, target humidity, mist level, light and its brightness, display, sound, child lock
  • Turn the head of a circulator a step left, right, up or down
  • Save the current settings as a preset, apply a preset, delete a preset
  • Switch off or on after … minutes, with the timer in the device itself, so it also runs when Homey is offline
  • An advanced card that sends any Dreo setting by its key, for things this app has no card for yet. The keys your device uses are in its settings in Homey, under “Dreo values”.
A few things people build with them:
  • :droplet: A notification when the dehumidifier tank is full.
  • :thermometer: Switch the heater on when the room drops below 19 °C, and let its own timer switch it off after two hours.
  • :leaf_fluttering_in_wind: Put the purifier on turbo when PM2.5 goes up, and on sleep at night.
  • :sun: Start the circulator when it gets warm, with the swing kept to the side of the sofa.
  • :bullseye: Switch the oscillation off at night and point the circulator at the bed.
  • :waving_hand: Let the circulator follow you while you are in front of it, and switch it off a few minutes after nobody is there.
:desktop_computer: Dashboard widgets
  • Dreo device: one device with all its controls, its presets and arrows for the head. Pick the device in the list at the top, so one widget covers all your Dreo devices. Mode and speed are always in view, the rest folds away under More.
  • All Dreo devices: all your Dreo devices in a list, with a power button each
:electric_plug: Energy
Each device type has an estimated power use for Homey Energy, which you can change per device.
:locked: Privacy
Homey stores an MD5 hash of your Dreo password, because the Dreo cloud asks for a new login now and then. Dreo accepts that hash as the password, so treat your Homey as you would treat your phone. The app talks only to the Dreo cloud: no server of my own, no analytics.
This app is not made by Dreo. It uses the same cloud service as the Dreo app without an official interface, so Dreo can change it at any time.
:memo: Changelog
1.3.0 (test version)
  • Ceiling fans: brightness, colour and effect of the ambient light, also from a flow and in the widget.
  • Air purifiers that report it get a Purification switch.
1.2.3
  • Timer cards: switching off or on after a number of minutes now reaches the device. Dreo rejected the old format, so the timer did not start.
1.2.2
  • Device widget: choose the device in a list at the top of the widget, so one widget covers all your Dreo devices. Thanks to Drako74.
  • Device widget: mode and speed stay in view, the rest folds away under More. The widget remembers if it was open. Thanks to Andy_Henderson.
1.2.1
  • DR-HAP003S: choose Standard or Soft for the auto mode. Auto from a flow now keeps the last choice instead of switching to Standard.
  • Widget: an Off button next to the ambient light colours.
1.2.0
  • Now in German, French, Italian, Spanish, Swedish, Norwegian and Danish.
  • Circulators with a body sensor: follow me, people detected and a presence alarm, with flow cards.
  • Turn the head of a circulator a step from a flow or the widget, like the arrows in the Dreo app.
  • Display with automatic brightness on fans, and a display mode (off, on, automatic) on newer heaters.
  • The mist of misting fans as its own switch, and auto mode on dehumidifiers.
  • Water level, filter life and hours of use where the device reports them, and a trigger when the target temperature or humidity is reached.
  • The DR-HPF017S rejects a new head position while the head still moves; positions now wait the time it needs.
1.1.3
  • Presets: save what a device does now under a name and bring it back from a flow or the widget. Thanks to Andy_Henderson.
  • Air circulators: brightness, colour and effect of the ambient light. Thanks to Andy_Henderson.
  • Air circulators: a fixed position now stops the swing on that axis first, because the head ignores it while swinging. Thanks to Drako74.
  • Heaters: a target of 19 °C showed as 18 °C on the device. Every Celsius target now arrives as set. Thanks to Drako74.
  • The widget is shorter: the number controls sit two by two, with left and right, top and bottom side by side.
  • The Dreo values in the device settings are separated by commas, so they stay readable on phones that show them on one line.
1.1.2
  • Air circulators: point the head in a fixed direction, horizontal and vertical, also from a flow. Thanks to Drako74.
  • The Dreo values in the device settings now show in full, one per line.
1.1.1
  • The DREO logo as the app icon.
1.1.0
  • Air circulators: set how far the head swings, left, right, up and down. Thanks to Drako74.
  • Dehumidifier: clear cards for a full water tank (“Water tank is full”, “Water tank was emptied”). Flows that used the old water tank cards of a dehumidifier need the new card.
  • New icons that look like the devices.
  • The Dreo values in the device settings now stay up to date.
Earlier versions
1.0.0
  • First version: nine device types, Flow cards for every setting and two dashboard widgets.
Something not right? Post it here with the model number of your device. The device settings show the values your device last reported under “Dreo values”, and those help a lot. :slightly_smiling_face:
OMG! This is awesome news. The official app has been a total bust, it doesn’t support any of their prior existing products, only 3 or 4 released around the same time as the app 5-6 months ago. And every time I’ve asked Dreo support, nothing but static in response.
Thank you so much for developing this app!
Glad it’s useful. You’re exactly the person I was hoping would show up: as I wrote above, I don’t own a Dreo device, so everything is built from the hass-dreo code and hasn’t touched real hardware yet.
If you have time, could you install the test version (DREO (Community) | Homey) and add a few of your devices? What helps most:
  • which models you have, and whether each one shows up when pairing
  • anything that’s missing, wrong, or works differently than in the Dreo app
  • for a device that misbehaves: the values under the device settings in Homey, copied in here
No rush, one device at a time is fine.
:rofl:
Sorry, I had to laugh… I have already installed it, added all 10 of my Dreo devices, and amended all my Flows to use this app. I’ve already disabled the old community test app by Lee, that sort of worked for most but not all of my devices. And deleted the Home Assistant imported devices that proved to be not a 100% reliable connection from Homey and lacked a lot of functions.
Initial observations:
The app logo, and the device card icons could possibly do with some work. The photos used for the app show Dreo products, but the icons look nothing like.
The WHEN cards for the dehumidifier to alert to the water tank being full or not are very confusing, and I have no idea until it fills up if I have the correct card or not.
The fan THEN cards lack the setting for oscillation angle, either horizontal or vertical. You can turn oscillation on and off, but not change the sweep angle. It does have a generic function card at the bottom of the list, but the Help tooltip says to look at the Diagnostic Report for the correct key values for the function… except not being an app developer, don’t have any access to those (a gripe of mine about Homey, that you can’t see any logging at all, so you can’t even try to resolve issues yourself first).
I’ll be using it day to day, so if I find anything else I’ll let you know.
Thank you again good sir :saluting_face: for creating this app. Do you mind if I link this thread on the main Dreo thread on this forum? I know there are other users out there who would love to try this (especially given the lack of support from Dreo themselves… I’ve been waiting literally all year to be able to use my Dreo devices with Homey).
Ha, you were way ahead of me. Thanks for testing this quickly, it’s exactly what I needed.
Version 1.1.0 is on the test link now, with your three points:
  • Oscillation angle on the circulators. Depending on the model you get four sliders for how far the head swings left, right, up and down (the sweep area in the Dreo app), or one angle per direction on older firmware. They show up on the device and as THEN cards. I couldn’t try this on a real fan, so tell me if a value doesn’t match what the Dreo app shows.
  • Dehumidifier water tank. It now has its own “Water tank full” value, with cards that say “Water tank is full” and “Water tank was emptied”. The old cards were wrong for a dehumidifier. If you already put one of them in a Flow, swap it for the new one after updating.
  • Icons. Redrawn after the actual devices: a round head on a stand for the circulators, a cylinder for the purifiers, and so on.
About the key card: you’re right, pointing to the diagnostics report was no help. You don’t need it. Open the device in Homey, go to its settings, and under “Dreo values” you see every key and value the device reports. Since 1.1.0 that list keeps up while the device runs, so you can change something in the Dreo app and see which key moves.
And yes, please link it in the Dreo thread. The more models get tested, the better.
You are most welcome good sir :saluting_face: Happy to help… and I’ve shared the link to this thread.
Installed and already testing. The oscillation angle is working a treat (as soon as I figured out the values range was -60° left to +60° right, and not 0° to 120° :rofl:). The Left and Right limits set individually is a nice call, gives the most flexibility of control. I’ve tested it with a couple of fans and it works great, thank you.
I tried this, unfortunately I could only see the first few values, as it was truncated, with no way to select more or scroll:
It would be nice for automations to be able to select a horizontal and vertical angle, for instance if your automation turns off oscillate, for you to be able to select a preferred direction rather than just wherever the oscillations happened to stop. You can do that in the Dreo mobile app, and as you can specify left, right, up, and down angle limits, I’m hoping this is possible to?
Thank you kindly good sir :saluting_face:
Good to hear the limits work on more than one fan. And yes, 0° is straight ahead, so left is negative and right is positive. Not obvious, I’ll give you that.
Version 1.1.2 is on the test link now, with both points:
Dreo values: this is now a text box with one value per line, so you can scroll through the whole list and copy it. Typing in it does nothing, it is only there to read.
Fixed direction: the circulators with the four swing limits also keep a fixed position for the head. There are two new controls, “Horizontal position” and “Vertical position”, with the action cards “Set horizontal position” and “Set vertical position”. For your example: switch oscillation off and then set the position, in the same flow.
One thing I couldn’t test: whether the head moves straight away when you set a position while it is still oscillating. If you try it, let me know what yours does.
If “Horizontal position” doesn’t show up on one of your fans, the Dreo values of that fan tell me why (look for fixedconf).
I’ll give it a test later and let you know… food first :smiley:
Many thanks for this and shame on Dreo.
I’ve tested it on my Polyfan which reports itself as DR-HPF008S.
Using the widget, everything works well. In fact, I find it a simpler and easier interface than the Dreo app.
I tried changing the limits while the fan was already oscillating and they are implemented immediately. So changing the top limit changes where the fan goes the next time it goes up.
Some feedback:
  • The widget has controls for starting and stopping horizontal and vertical oscillation, and for setting limits, but the device tile allows me to only switch the fan on and off and set the fan speed. Similarly I can turm ambient light, panel sound and child lock on and off in the widget, but not the device tile. I can set the mode in both the widget and the device tile.
  • There’s no way to set the ambient light: colour, brightness or mode (the Dreo app gives me options for constant, breath, and cycle).
  • The widget is long. There’s scope to show left/right limit settings and up/down limit settings side-by-side to reduce the length.
  • In advanced settings, ‘Dreo values’ do not show line by line in my Andoid Motorola phone in either the advanced settings page or the dedicated Dreo values page. They do, however, show line by line in the Windows app (listed below).
My biggest issue with the Dreo app (besides its over-complicated UI) is that it doesn’t let me store and recall preset settings. For example, I would use different sets of values depending on how many people are in the room and where they sit. I can use your app to implement presets via flows but the ability to save them from the device tile and retrieve them from a widget (perhaps a simpler version of the existing one) would be very helpful. But I completely understand if that’s a step too far for you.
These are the Dreo values reported by the app:
_ota=2, alignon=true, atmbri=2, atmcolor=12799, atmmode=1, atmon=true, atmspeed=1, childlockon=false, connected=true, cruiseconf=15,60,-30,-25, customconf=temp:12222223333334444447777778, fanon=false, fixedconf=0,0, lightmode=0, mcu_firmware_version=0.1.0, mcu_hardware_model=SC95F8615B/EU, mcuon=true, mode=1, module_firmware_version=3.8.3, module_hardware_mac=xxx, module_hardware_model=HeFi, muteon=false, network_latency=71, oscmode=2, rssi={“max”:-48,“min”:-50,“avg”:-48}, scheid=-487555138, scheon=false, temperature=63, tempoffset=0, wifi_rssi=-42, wifi_ssid=xxx, windlevel=1, wrong=0
Just installed, so far so good, will look to play around with it when I get some time over the weekend.
Appreciate your efforts
Hi Andy,
The DR-HPF008S is the Turbo PolyFan 508S. I have one of those, and I can access all the controls via the device tile, except for the LED ambient light.
I haven’t had chance yet to test all controls, or had chance to look at the widget yet. But I have tested several of my Turbo PolyFan 513S, my dehumidifier, and Atom S fan heater. Apart from a small bug with the set temperature not allowing me to set 19°C for some odd reason… it shows 18 on the device when the app shows 18, but also shows 18 on the device when the app is changed to 19. Then jumps to 20 when you increase the app to 20 on the fan heater. But the fans, air purifiers and dehumidifier seem to work fine.
The developer not having any of these devices, there are bound to be the odd little bug :bug: here and there. But considering the :poop: show the official Dreo app has been, this is incredibly mighty impressive.
EDIT:
@weide43 If you try to set static angle while oscillating is still on it just ignores it. Once you stop oscillation it will let you select a static angle. And the static angle position, and the oscillation limit angles match up in Dreo’s own mobile app perfectly.
Only problems I have found so far are the aforementioned bug :bug: with the heater set temperature, and lack of LED ambient light control on the PolyFan 508S (but that is an unusual one… their only model I think that has an RGB light ring). From what I have tested so far with my flows and presence sensors changing devices settings if in the room or not, and depending on temp & humidity sensors… they all seem to be working fine so far. And I am able to access the key values now, thank you
I’ll do more testing over the coming days. Mahoosive appreciation for all your work so far on this, respect :raised_fist:t3:
Thanks both, this helps a lot. Version 1.1.3 is on the test link now.
@Andy_Henderson
  • Presets: the widget has a row “Presets” with “+ Save as preset”. It keeps mode, speed, swing, limits, position and the ambient light under a name, and one tap brings it all back. The same works from a flow with “Save the current settings as preset”, “Apply a preset” and “Delete a preset”. Child lock and panel sound stay out of it.
  • Ambient light: brightness, colour and effect (constant, cycle, breathe), also as flow cards. The colour is a choice of nine; if you picked another colour in the Dreo app, the nearest one shows. Changing any of them also switches the light on.
  • Widget: shorter now. The number controls sit two by two, left next to right and top next to bottom.
  • Dreo values: each value now ends with a comma, so on your phone they should at least read as a list.
  • Device tile: Drako74 sees all the controls on the same model, so the app does give them to your fan. Could you post a screenshot of what you see? On some screens the extra controls only show when you scroll down or swipe.
@Drako74
  • Fixed position: thanks for testing. Setting a horizontal or vertical position now stops the swing on that axis first, in the same command. Let me know if the head moves straight away now.
  • Heater at 19 °C: found it. The heater works in Fahrenheit and rounds down when it shows Celsius, so 19 °C went out as 66 °F and showed as 18. It now goes out as 67 °F, as the Dreo app does, and every whole degree should arrive as set.
Version 1.2.0 is on the test link, with what I still found in hass-dreo:
  • The app now also speaks German, French, Italian, Spanish, Swedish, Norwegian and Danish.
  • Circulators with a body sensor get “Follow me”, “People detected” and a presence alarm, so a flow can react when someone sits down in front of the fan.
  • Arrows in the widget and a flow card turn the head a step, like the arrows in the Dreo app.
  • Where the device reports it: automatic display brightness, the mist switch of misting fans, water level, filter life, hours of use, and a trigger when the target temperature or humidity is reached.
  • The DR-HPF017S gets 8 seconds between two head positions, because it rejects a new one while the head still moves.
None of this is tested on a real device. If one of these shows up on yours, let me know whether it does what it says.
That’s terrific. Many thanks. Your app is now far superior to the Dreo phone app - easier to use and the preset option is a game-changer.
I can confirm:
  • Presets work well
  • I’ve found the drop down options in the device tile pages (might be good to make them more prominent if possible - I saw them as titles. missing the little down arrow)
  • Ambient light options work well - it amused me that you used ‘Breathe’ as an option; the Dreo phone app incorrectly says ‘Breath’. However, there’s no way to turn the light off from the widget. Maybe a second tap on a colour or an extra ‘Off’ option in the light effect section.
  • Widget is shorter and looks better. It’s still a big widget. An option to collapse everything below ‘Fan speed’ might help people with limited space on their dashboards. Not a big deal as I can put the widget in a dashboard of its own.
  • Values presentation is line by line now.
Very impressive. Thanks again.
Andy
That’s Homey’s standard way of presenting multiple settings, I’m not sure if an app can influence how that is displayed.
I have found a slight bug :bug: with my DR-HAP003S air purifier. This app offers the mode options of Auto, Manual, Sleep, and Turbo. Which is the same as the Dreo mobile app. But the Dreo mobile app offers an additional setting of Auto Mode Settings: Standard or Soft.
Which this app doesn’t replicate, but seems to change whenever my Flow turns the device on, from Soft to Standard (which is far noisier) so I have to then open the Dreo Mobile app (which still reports being set to Soft) and change it to Standard and apply, then open the setting again and change it to Soft and apply every time I enter the room.
I have had a look in the Dreo Values in settings, but can’t see anything obvious that pertains to this setting, or why the Dreo mobile app would think it is still set to Soft, when the automict fan speed can raise much faster than that setting limits.
_ota=0
aq=1
aqi=100
childlockon=false
connected=true
dispmode=pm25
ledalwayson=true
lifetime=22
lightsenon=false
lightsenval=255
mcu_firmware_version=0.1.5
mcu_hardware_model=SC95F8616B-2/US
mcuon=true
mode=auto-silent
module_hardware_mac=**********
muteon=false
network_latency=23
pm25=1
poweron=true
rssi={“max”:-62,“min”:-67,“avg”:-65}
scheid=0
scheon=false
wifi_rssi=-65
wifi_ssid=**********
windlevel=10
wrong=0
I ran the Flow that’s triggered when I walk in the room to turn it on, then went to the Dreo mobile app and changed the setting back to my preferred default of soft, then ran a diagnostic report, in case that shows you something helpful.
Diagnostic Report ID: 3788d604-2214-4ba9-8e17-f498d4751fc3
1.2.1 is on the test link, and in review for the App Store: https://homey.app/a/be.dreocommunity/test/
@Drako74 thanks for the report, it showed exactly what goes wrong. On your DR-HAP003S, “Auto” is really two modes: auto-regular is Standard and auto-silent is Soft. That is also why your Dreo values say mode=auto-silent after you set it back to Soft. When a flow set the mode to Auto, the app always sent auto-regular, so the purifier jumped to Standard every time you walked in.
In 1.2.1:
  • The purifier gets a new setting “Auto mode” with Standard and Soft, also as flow cards (set it, a trigger when it changes, and a condition).
  • Auto from a flow keeps Soft when the purifier is already on Soft, and coming from manual or sleep it goes back to the Standard or Soft you used last.
After the update, set Auto mode to Soft once (in Homey or in the Dreo app), so the app knows your choice. If your flow only switches the purifier on and doesn’t set a mode, let me know, because then something else is going on.
The Dreo app still showing Soft is the Dreo app itself: it shows the last choice made in that app and doesn’t read it back from the purifier.
@Andy_Henderson glad the presets work for you! The widget now has an Off button next to the ambient light colours, and tapping a colour turns the light back on. The “Ambient light” button at the bottom of the widget already did this, but it was easy to miss, so it moved next to the colours. A shorter widget with the rest folded away is a good idea, I’ll keep it in mind. And Drako74 is right about the drop-downs on the device page: that is how Homey itself shows them, an app can’t change it.
Ahhh, D’oh! I couldn’t see the wood for the trees :rofl: Perhaps I should have gone to SpecSavers ha ha.
Thank you for that, minor I know, but irritating none the less… So your very prompt fix is mahoosively appreciated!
EDIT:
Tested and working great thank you. I also inadvertently tested my living room smoke alarm, and tested my heart doesn’t have an attack too :rofl::rofl::rofl:
Sorry, should have spotted that, but the new position is much better.
Understood. I’ve had a look through all my devices in case I’m missing a trick but only one (my doorbell) has multiple options and that doesn’t give me anything useful. I’ll keep an eye open for it in the future.
Thanks again,
Andy
I have finally got around to exploring the widgets, and they are great… so please don’t take this request as negative… but would it be possible to have a device widget that has a drop-down menu at the top, where you can select a device? That would be immensely useful (imagine how many dashboards I’d need to individually show each of my 10 devices around my home ha ha ha).
I’m thinking something along the lines of what Thomas did for the WidgetKeeper app media player widget… so I’m guessing there would be a way to implement it:
I’m presuming a fair bit here I know, but from what I’ve seen with other widgets they can dynamically resize, and load in a list of devices. So I’m hoping that would be possible for all devices installed under the Dreo app. I hope that makes sense… :grimacing:
This app really has been a game changer for my home automation, and something I’d been hoping for for a very long time.
