Disabled users and presence
I have 4 accounts, 2 are disabled.
I want to use the option ‘nobody is home’ but the 2 disabled accounts are seen and always home… as such the flow never works. It seems to me that disabled accounts should be gone in presence also to use this option.
I’ve seen this mentioned before here so I think it is a bug only Athom can fix. So be sure to put in a bug report.
As a workaround, Is it possible to re-enable the accounts, set them away and disable them again? Or can you still set them away using a flow?
I’ll try the workaround, thx!
Workaround seems to be working :grin:
