Danalock App PIN Management
Hi, as far as I know you can manage PIN codes with the Danabridge in place via my.danalock.com.
I wonder if the Homey App fo the Danalock will make this feature also available?
Any ideas on this?
Danalock with the Homey doen’t use the bridge, but has a direct connection with zigbee or zwave.
Pin is not available it this moment
Let’s get this back to live!
I saw the developper added the flow card ‘set pin(id-pin)’ and delete pin.
However, my homey isn’t connected to the danapad, but rather only the lock itself (ZigBee) this pincodes are stored within the danapad.
Would a Dana ridge be nesicerry for this feature to work?
Hi.
I wonder if i can connect the DanaPad to Homey.
Want to get info in to history on who opens or unlock the door with a code. So what i want is when i type in my code to unlock, a flow put into history that i have unlock the door.
yes I agree, it would have been nice to have Danapad in Homey Pro. Then you can keep a log of who comes and goes, as well as have your own flow that starts when a person uses their code to unlock
