Curtain modul 24v DC
I have a curtain motor which I would like to connect to homey using ZigBee protocol but this motor works with 24v DC alimentation and not 220v AC…
I only have 24v DC close to the place where I want to put the module and I would like to use the ZigBee protocol to increase my mesh.
Currently, the only device that I found is the Shelly 2.5 but this later is a WiFi module. Do you know if I it exists an alternative which is ZigBee compatible (and which works with Homey pro :wink: ).
Best
Jérôme
Nobody :frowning: ?
qubino flush will work
but thats Z-wave then but compatible with Homey
Thanks, @stig_hansen. I will check it also then.
So it seems that there is nothing equivalent using ZigBee…
Best.
Jérôme
