Current State of Matter in Homey: Overview of what's supported, compared to the full Matter spec
Since this keeps coming up in the forums I though I create this post that I will update on major Homey/Matter releases to document the current state of Matter in Homey.
Current State as of 22. October 2026
I compared the Matter code in Homey 13.5.3 with the official Matter data model for every spec version from 1.0 to 1.6.1 (the device type and cluster definitions in the open-source Matter SDK, connectedhomeip).
This is based on reading the code, not on testing devices. “Supported” means Homey has code that turns that part of Matter into Homey capabilities, settings or flow cards. Individual devices can still behave differently.
TL;DR
  • Up to Matter 1.4.2, Homey covers nearly everything. 52 of the 53 device types a hub is meant to control work in some form, 42 of them fully.
  • Matter 1.5 is about half covered. Of its 16 new device types, 6 are fully supported (Chime, Doorbell, Soil Sensor and three electricity meter types), 2 partly, and 8 not at all: cameras, video doorbells, intercoms, the new closures (gates, garage doors) and energy tariffs.
  • Matter 1.6 adds no new device types, only three clusters, and none of them are supported yet.
  • Against the full 1.6 standard: 48 of 69 device types are fully supported (70%), 12 partly (17%) and 9 not at all (13%). Homey implements 62 of the 99 application clusters (63%).
  • Inside the supported device types, sensors, buttons, lights and appliances are nearly complete. Thermostats, door locks, EV chargers and media players only get the basics.
Support per Matter version
Each version includes everything from the versions before it.
Matter version Device types¹ :white_check_mark: Full :warning: Partial :cross_mark: None Application clusters supported
1.0 / 1.1 25 20 4 1 20 of 36
1.2 34 29 4 1 45 of 61
1.3 45 39 5 1 55 of 77
1.4 / 1.4.1 53 42 10 1 59 of 83
1.4.2 53 42 10 1 59 of 82²
1.5 / 1.5.1 69 48 12 9 62 of 97
1.6 / 1.6.1 69 48 12 9 62 of 99
¹ Device types a hub is meant to control. Not counted: 9 infrastructure types (root node, bridge, OTA, power source and similar) and 13 controller-only types (explained further down).
² One cluster fewer than 1.4.1 because the spec dropped Ballast Configuration, a draft cluster that was never finalized or used by any device type.
  • :white_check_mark: Full: Homey has a device class for it and implements all its required clusters.
  • :warning: Partial: it works, but some required parts are missing, or Homey has no device class for it and it pairs as an “Other” device whose capabilities still work.
  • :cross_mark: None: it pairs, but does nothing useful.
The low cluster share for 1.0/1.1 is mostly the 13 TV and casting clusters, of which Homey uses 2.
Device types (Matter 1.6)
Area :white_check_mark: Full :warning: Partial :cross_mark: Not supported
Lighting On/Off Light, Dimmable Light, Color Temperature Light, Extended Color Light
Plugs & load control On/Off Plug-in Unit, Dimmable Plug-in Unit, Mounted On/Off Control, Mounted Dimmable Load Control, Pump
Buttons Generic Switch
Sensors Contact, Light, Occupancy, Temperature, Humidity, Pressure, Flow, Air Quality, Smoke/CO Alarm, Water Leak, Rain, Soil Sensor :new_button: Water Freeze Detector³
Closures Door Lock, Window Covering Closure, Closure Panel
Climate Thermostat, Fan, Air Purifier, Room Air Conditioner Heat Pump⁴
Appliances Refrigerator, Temperature Controlled Cabinet, Washer, Dryer, Dishwasher, Robot Vacuum, Oven, Microwave, Cooktop, Cook Surface, Extractor Hood
Water Water Valve Irrigation System³
Energy Electrical Sensor, Water Heater, Electrical Meter :new_button:, Electrical Utility Meter :new_button:⁵, Meter Reference Point :new_button:⁶ EV Charger⁷, Solar Power⁴, Battery Storage⁴ Electrical Energy Tariff
Media Speaker Basic Video Player⁸, Casting Video Player⁸ Content App
Doorbells & cameras Doorbell :new_button:, Chime :new_button: Audio Doorbell⁹ Camera, Snapshot Camera, Video Doorbell, Floodlight Camera, Intercom
Network Network Infrastructure Manager¹⁰, Thread Border Router¹⁰
Generic Mode Select³
:new_button: Fully supported since 13.5.3.
³ Works, but Homey has no device class for it, so it shows up as “Other”.
⁴ Readings only. Device Energy Management isn’t supported, so there is nothing to control.
⁵ Meter details only (meter type, serial number, power threshold), shown in the device settings.
⁶ A base type the other meter types build on. It has no functions of its own.
⁷ Charging on/off works. Charging modes (required by the spec) and charge planning don’t.
⁸ On/off, playback and keypad work. No input switching or app launching.
⁹ Doorbell button only, no audio or video.
¹⁰ Gets a router device class, but none of its clusters are implemented, so there is nothing to see or control.
Clusters (Matter 1.6)
Area Supported :white_check_mark: Supported :cross_mark: Not supported
General 8 of 12 On/Off, Level Control, Switch, Boolean State, Boolean State Configuration, Mode Select, Operational State, Service Area Scenes Management, Actions, Messages, Temperature Alarm (1.6)
Lighting 1 of 1 Color Control
Sensing 22 of 23 Temperature, Humidity, Pressure, Flow, Illuminance, Occupancy, Air Quality, Smoke/CO Alarm, 10 concentration clusters (CO, CO₂, NO₂, ozone, PM1, PM2.5, PM10, formaldehyde, TVOC, radon), HEPA and activated carbon filter monitoring, Water Tank Level, Soil Measurement :new_button: Ambient Context Sensing (1.6)
Climate 4 of 4 Thermostat, Thermostat UI Configuration, Fan Control, Pump Configuration and Control
Closures 2 of 4 Door Lock, Window Covering Closure Control, Closure Dimension (1.5)
Water 1 of 1 Valve Configuration and Control
Appliances & robots 15 of 15 Laundry Washer Mode, Laundry Washer Controls, Laundry Dryer Controls, Dishwasher Mode, Dishwasher Alarm, Refrigerator Mode, Refrigerator Alarm, Temperature Control, Oven Mode, Oven Cavity Operational State, Microwave Oven Mode, Microwave Oven Control, RVC Run Mode, RVC Clean Mode, RVC Operational State
Energy 6 of 15 Electrical Power Measurement, Electrical Energy Measurement, Energy EVSE, Water Heater Management, Water Heater Mode, Meter Identification :new_button: Device Energy Management, Device Energy Management Mode, Energy EVSE Mode, Energy Preference, Power Topology, Commodity Price, Commodity Tariff, Commodity Metering, Electrical Grid Conditions
Media 2 of 14 Media Playback, Keypad Input Media Input, Channel, Target Navigator, Audio Output, Low Power, Wake on LAN, Content Launcher, Application Launcher, Application Basic, Account Login, Content Control, Content App Observer
Cameras & chimes 1 of 7 Chime :new_button: Camera AV Stream Management, Camera AV Settings, WebRTC Provider, WebRTC Requestor, Push AV Stream Transport, Zone Management
Network 0 of 3 Wi-Fi Network Management, Thread Border Router Management, Thread Network Directory
The other 36 clusters in the spec are utility clusters (pairing, security, diagnostics, labels). Homey uses the ones it needs for pairing, firmware updates, battery status, bridges, sharing with other Matter apps and network info. Groups and Binding are not used.
How deep the support goes
A supported cluster doesn’t always mean everything in it is available. Grouped by what you can actually do:
Complete or nearly complete
Buttons (single, double, long press and release triggers), contact/leak/rain/freeze sensors, temperature/humidity/pressure/flow/light sensors, air quality and pollutant sensors, occupancy sensors, soil moisture, color lights (hue/saturation, xy, color temperature, color loop), chimes (pick a sound, turn on/off, play from a flow), meter details, appliance and robot vacuum programs and modes, start/stop/pause/resume for appliances, temperature control, washer/dryer/microwave settings, pumps, water heater boost and Mode Select.
Small gaps: no peak or average values for pollutants, and no “cycle finished” event or remaining time for appliances.
Good basics, some gaps
Function What you get What’s missing
On/Off On/off, power-on behaviour setting Timed on, effects
Dimming Dim level, transition times, dim up/down flow cards Step commands, on-level and min/max settings
Blinds Lift and tilt %, open/close/stop, invert setting Absolute positions, safety status. Homey shows the target position, not the current one
Smoke/CO alarm Smoke and CO alarms, including interconnected alarms Low battery, hardware fault and end-of-life all show as one generic alarm. No self-test or mute
Robot vacuum rooms Clean selected rooms (flow card) Current room, progress, skip room, maps
Filters Filter life %, replace warning Resetting the filter after replacing it
Power metering Power, voltage, current (also 3-phase) Frequency, power factor, reactive and apparent power
Energy metering Imported and exported kWh Periodic energy reports, so devices that only send those show no kWh
Water valve Open/close, opening level Open for a set time, auto-close timer, fault reports
Battery Battery %, low battery alarm Charging state, mains status, time remaining
Fan Fan mode, speed %, swing Natural/sleep wind, airflow direction, speed steps
Basic only
Thermostat Off/heat/cool/auto, one setpoint, room and outdoor temperature, temperature offset Presets like Home/Away/Sleep (Matter 1.4), schedules, away setpoints, whether it’s actually heating or cooling right now, heating demand %, fan-only and dry modes
Door lock Lock, unlock, unbolt; normal/vacation/privacy/passage mode; door open or jammed; relock time, LED and volume settings Lock events (who or how it was unlocked, wrong-code alerts), users and PIN/RFID/fingerprint management, access schedules, Aliro, timed unlock. Homey doesn’t send a PIN, so locks set to require one for remote operation will refuse commands
EV charger Enable/disable charging and discharging, charging state, car battery %, max current Charging modes, scheduled charging and charge targets, session energy and duration, “car connected” and fault events, RFID
Media player Play, pause, stop, next, previous, track duration Seek, skip, rewind and fast-forward, playback position, audio and subtitle tracks, input switching
The biggest gaps
  • Cameras, video doorbells and intercoms (Matter 1.5)
  • The new closures: gates, garage doors and similar (Matter 1.5)
  • Energy management: no load control for heat pumps, batteries, solar or EV charger modes, and no energy prices or tariffs (Matter 1.3–1.5)
  • Thermostat presets and schedules (Matter 1.4)
  • Door lock users, PINs and lock events
  • Scenes and groups
  • Switches that control lights directly (binding, see below)
  • Media control beyond play/pause
What “controller-only” means
Some Matter device types work by sending commands to other devices instead of being controlled: light switches, dimmer switches, and remotes for blinds, locks or thermostats. In Matter, these are meant to be bound directly to the device they control. Homey only reads what a device itself offers. It doesn’t set up bindings and can’t act as a binding target, so these types do nothing on their own in Homey.
Most Matter buttons and switches also include a Generic Switch, and that does work: press, long press and multi-press show up as flow triggers.
The 13 controller-only types: On/Off Light Switch, Dimmer Switch, Color Dimmer Switch, Control Bridge, On/Off Sensor, Door Lock Controller, Window Covering Controller, Pump Controller, Thermostat Controller, Closure Controller, Camera Controller, Casting Video Client and Video Remote Control.
Small things I noticed in the code
  • Cluster library version not bumped in 13.5.3: the code says this number must be raised when clusters are added, so already-paired devices get re-checked. It’s still at 2, which is why existing chimes, soil sensors and meters probably need re-pairing (see “New in 13.5.3”).
  • Water Freeze Detector (Matter 1.3): the freeze alarm is implemented, but the device type is missing from Homey’s device-class list, so it pairs as “Other”.
  • Network Infrastructure Manager and Thread Border Router get a router device class but have no capabilities.
  • More Matter 1.5 groundwork is there: Homey’s bundled Matter definitions already include every Matter 1.5 cluster, including the camera and closure ones. Only the mapping to Homey devices is missing.
  • Possible typo: in the conflict list for lights, Dimmable Light appears twice. The second entry looks like it was meant to be Dimmer Switch.
How I checked
  • Spec side: the device type and cluster definitions for each Matter version, from the data_model folder of project-chip/connectedhomeip (1.0 to 1.6.1).
  • Homey side: the Matter code shipped with Homey 13.5.3 (also compared with 13.5.0), specifically the list that maps Matter device types to Homey device classes, and the cluster library that turns clusters into capabilities, settings and flow cards.
  • A device type counts as fully supported when it has a Homey device class and all its required clusters are implemented.
  • Depth: which features, commands and events each supported cluster’s code actually uses.
  • Not tested on real devices, so individual products can behave differently.
Any signs if self built (uncertified) sensors now is supported?
I built some DIY Matter devices and as long as you use the clusters above correctly they will work. You just need to dismiss a warning while adding them, because they are uncertified.
