Critical push notifications
The latest updat of homey app on ios mentioned the support for critical push notifications. I was looking for the setting to configure that critical push notifications are always displayed and accompanied with a sound. Can’t find it though.
Was anybody able to configure and use critical push notifications?
You’ll first need to enable this feature. In the mobile app. Go to More tab > Permissions and enable the Critical Alerts permission:
To send a critical alert use the new dedicated THEN push notification flow card:
Result:
Small note on this☝🏽
Unfortunately, it is not possible to adjust the volume for critical alarms, so that they then sound very loudly. This is a pity and brings only a small added value!
With other apps such as the app from Ajax (alarm system) the volume can be set.
On iOS the sound associated with the critical alert is played very loudly; louder than normal. Perhaps on Android it is not :thinking:?
Either way, you cannot seem to set the volume yourself.
No, its not loud for me🧐
I have also iOS
Compared to the other apps, it’s way too quiet in my opinion.
Unless you have the volume on very loud for all push messages, but that is basically not the opinion of a critical message…
No, I have the normal volume set to approx 25%.
When I send such a critical alert it sounds like it is on full volume, so very loud. Strange that it seems to work differently in your case.
That’s weird, I have the volume much higher than you🤔
What iPhone do you have?
I have 14 Pro
Maybe my speaker is broken…:flushed_face:
iPhone 13.
Anyone else not getting the critical notifications option?
Latest app is installed running ios 18.4.1
My homey pro 2019 is running v12.4.1
Same here
First, make sure you update to the latest software versions. Currently, The latest app for iOS is 9.2.2. The latest firmware for Homey 2019 is 12.4.2.
v9.2.3
I dont see it yet by the way in my appstore …
I don’t have the option for Critical notifications under “Permissions”. I have updated Homey to 12.4.2, the Homey app to 9.2.2 and my iPhone is iOS 18.4.1. I have also restarted Homey and my phone. Still, I only have Bluetooth, location and notifications under “Permissions”.
What am I missing? :thinking: Is there a phone hardware limitation here? I have a iPhone SE.
I have the same issue. Running iphone 14 pro.
Good to know…then it should not be my hardware that is the issue…since the 14 Pro is a much higher tier phone than the SE.
Same issue, iPhone 15Pro. Crazy…
Here on Iphone 16 in silent mode it works.
iOS 18.5 beta)
What model of homey pro are you using?
On my 2019 it does not show the option for critical notifications.
So you did get the option under “Permissions” to turn on Critical notifications?
Klick on settings (in my picture instellingen)
Then you automaticly go to settings in your Iphone:
