Hi!
Is there any solution to critical alerts on samsung phones? I have a fully updated S25 and it will not play a sound as long as i have it on sound off. I have given it permissions to notifications on critical alerts and so on.
Please advise.
Hi!
Please advise.
Hi. Thanks.
I have it all activated like that. But since i have my phone with sound off. It will never play any sound..
Do you mean “do not disturb” in samsung?
Then open setting for the do not disturb - app notifications - select app /homey in this case
No, i just always have the sound turned off. Every volume on mute.
I hoped that critical alarm would be able to bypass this
It works in unifi protect. Same settings. There the sound breaks trough
Maybe this is of any use. With the Samsung app called Sound Assistant, it’s possible to turn of sounds of any app but Homey
https://apps.samsung.com/appquery/appDetail.as?appId=com.samsung.android.soundassistant
Other idea: when you enable Do not Disturb mode 24/7, and leave Notification sounds on, you can exclude Homey app
You might be able to use Modes and Routines on Samsung. Then you can send a notification from Homey like SOUNDON, which the Routine will trigger on and turn the sound back on. Then, your Flow should send a critical alert which will now sound. You can add a delay to the Routine which will disable the sound again in 30 seconds
Thanks for all the suggestions. I have been in contact with homeys support and the can reproduce the problem. I hope they will fix it instead of workarounds.
