I’ve been using android since the first HTC.. Now on a Samsung ultra..
But I can’t find any place in android or in the app to set notification sound depending on event?
I get the standard system sound for regular notifications but the alerts from the alarm and water leaks and such.. It’s got to be the most stupid song I’ve hear as an alarm sounds..
As a work around in the meantime you could use an app like pushover along with its partner Homey app to send alerts and then you can customise alert sounds. Gives you lots more options as well.
Yes it’s One UI 7, I didn’t know about that (significant) change in sound settings.
When apps are supposed to manage sounds with One UI 8, your best shot is to contact Athom support https://homey.app/support
My tablet runs One UI 8 as well, and same as your phone: no way to change sounds.
I didn’t notice yet cause my tab is not allowed to make any noise whatsoever
Newer need to think about it tbh..
I think all other apps where I use a different sound have updated already..
Then again, it’s not very often you set a specific sound for an alert.
Except when using it for alarms of different kinds..
I dont know if this helps, but I was trying to find how to change alert sounds for apps like Homey in newest versions of android too.
You have to enable this in phone settings at first:
Go to Settings->Notifications->advanced settings->Manage notification categories for each app and turn on
Long press the app which you want to change, select the “i” and then select notifications. Select notification categories and there you can change sounds for each individual notification category.
