I’ve been having an issue for some time now where I no longer get any sound alerts from Critical Alerts.
I use several different apps that support Critical Alerts, including Homey.
I have two iPhones connected to my account, and previously both phones would play an audible alert whenever a Critical Alert was triggered.
I’ve already tried the following:
- Updated both iPhones to the latest version of iOS.
- Checked the notification settings in the Homey app and confirmed that Critical Alerts are enabled.
- Confirmed that notifications and sounds are enabled in the Homey app.
- Tested with both Silent Mode enabled and disabled.
- I don’t have an Apple Watch.
- Tested with Bluetooth disabled.
Is anyone else experiencing a similar issue, or does anyone have any suggestions on how to fix it?
It feels like this could be an iOS bug, but I haven’t been able to find any recent information about it.
Any help or suggestions would be greatly appreciated!
Thanks in advance!
That pattern (silent Critical Alerts on more than one iPhone, after you already checked the Homey app toggles and Silent Mode) is often still an iOS-side permission, not the flow itself.
On each iPhone, open Settings → Apps → Homey (or Settings → Notifications → Homey) and confirm that Notifications, Sounds, and Critical Alerts are all allowed. After an iOS update the Critical Alerts switch sometimes resets, or it stays on in the Homey app while iOS has revoked it. If you use Focus, also open the Focus profile and check that Homey is allowed to break through, including Critical Alerts; a Focus that looks “off” can still be scheduled.
Also check Settings → Sounds & Haptics: a volume of zero, or “Change with Buttons” left off after someone muted the ringer, will silence even critical tones. Notification Summary / Scheduled Summary should not include Homey if you need immediate sound. Low Power Mode and a long “Deliver Quietly” state are worth turning off for a test.
To separate an iOS bug from a Homey issue: trigger a Critical Alert from another app that you know used to play sound on the same phones. If those are silent too, it points to the OS. If only Homey is silent, delete the Homey notification permission (or offload/reinstall the app) and grant Critical Alerts again when prompted, then reboot both phones.
I would not assume a widespread iOS bug until that comparison is done; a permission that silently dropped after an OS update is more common.
See above
Did you reboot the phone(s)?
If that didn’t solve it, try this with one of the phones:
Remove Homey app → reboot phone → install Homey app
Hi!
Thank you so much for all your help.
The issue was resolved by uninstalling Homey and re-enabling all critical notifications.
Thanks again!
