Create-homey-app - Create Homey-App without build configuration
Create Homey App
This app is still under development
Create Homey-App without build configuration. In a single command, this tool bootstraps an app with associated version management and a dockerized remote development environments.
“Old” apps can also be upgraded, if the command is called in the existing app-root directory.
Create Homey App works on macOS, Windows, and Linux.\
If something doesn’t work, please file an issue.\
If you have questions or need help, please ask in Homey Community Forum.
Requirements
Quick Overview
npx create-homey-app [my-app]
cd my-app
code .
If you’ve previously installed Homey Command-line interface globally via npm i -g homey, we recommend you uninstall the package using npm uninstall -g homey or yarn global remove homey to ensure that npx always uses the latest version.
(npx comes with npm 5.2+ and higher, see instructions for older npm versions)
Note
This is my second attempt to normalize and simplify the structure of my homey app development environment with VSCode.
Creating or update an Homey-App
npx
# Invoking from the npm registery
# Invoking from the github repository
npx github:cghome/create-homey-app [my-app]
npm
npm init homey-app [my-app]
npm init <initializer> is available in npm 6+
Yarn
yarn create homey-app [my-app]
It will create a directory called my-app inside the current folder.
Inside that directory, it will generate the initial project structure and install the transitive dependencies:
Add on’s
Homey debugger
Add to app.js
* homey-debugger
/* eslint-disable */
if (process.env.DEBUG === "1") {
require("inspector").open(9229, "0.0.0.0", false);
// require("inspector").open(9229, "0.0.0.0", true);
/* eslint-enable */
What’s included
npm-scripts
  • test - homey app run
  • start - npm install && homey app install
  • build - homey app build
  • publish - homey app publish
  • postpublish - npm run init && git commit --amend --no-edit ./package.json && git push -f origin main
  • validate - homey app validate -l publish
  • validateTest - homey app validate
  • init - npm init --quiet -y 1>/dev/null
  • lint - eslint .
  • createRemoteRepo - hub create -d “$npm_package_description” -h npm_package_homepage {PWD##*/} && git commit --amend --no-edit && git push -u origin main
For Developers
Install Create-Homey-App
git clone https://github.com/cgHome/create-homey-app.git
cd create-homey-app
npm link
code .
# happy coding
# Test app > use JavaScript Debug Terminal
Tutorials
Development Container Tips & Tricks
Create apps
Changelog
v0.1.0
  • Initial commit
ToDo
  • Add Screencast
  • Add localHomey - Parameter
Copyright
Copyright 2021, 2021 [Chris Gross] cFlat-inc.org
For later use….
