Create flow for thursday on odd weeks?
Hello Guys,
Can anyone help me build a flow, that starts every thursdag on odd weeks ?
I cant seem to find a option for odd/even weeks.
Easy enough starting a flow every 14 days but unsure off the top of my head about every Thursday on odd weeks. I can see logic cards and maths being used.
Starting on a Thursday could be done manually and let the flow run but there will likely be a more elegant way than that
Something like this.
The result is true today btw :wink:
Between Thursday and Thursday is a bit strange, but you’d read it like timestamps:
Between Thursday 0:00 hrs (new day)
and Thursday 23:59:59 hrs (end of day)
My Weeknumber looks like this:
I cant pick ODD or EVEN, is something wrong ?
Interesting. I have as Peter has shown, in advanced flows, and can invert it to be even weeks. Not sure how your example has happened.
Cold even add a time of day condition as well
That’s ODD (sorry, couldn’t resist :wink:).
Looks like a translation error of some kind, because {{odd|even}} should be in the code, not in the card.
In English it shows as:
So, to see for myself I changed Homey’s language to Danish, and:
Confirmed it has something to do with the translation to Danish. There’s also another card with {{some-text}}
I just reported this issue to Athom @ Slack, and it will be fixed with one of future firmware updates.
The trigger I used triggers right after midnight, so I think one should trigger the flow like “When it is 09:00 AM”
Then, that flow starts the action cards on Thursdays on odd weeks at 9 AM
Maybe I misunderstand you again, but why you use the condition card “Day is between Thursday and Thursday” instead of “It’s Thursday”?
Hello Peter,
Thanks, I just tried to change lang to English, and it worked now.
I can now go on with my flow.
Thanks for your help.
Hello Fantross,
I need a flow checking if week is odd, and if thursday at 14.00 it should turn on elektricity in 3 rooms.
Then I will create a new flow check if week is odd, and on sundays at 8pm, it will turn socket off.
Sorry, only in German:
When…
— The time is 14:00
And…
— The weeknumber is odd
— Today is Thursday
Then…
— Turn on
What I don’t understand is, why @Peter_Kawa uses „The day is between“ instead of „Today is“.
Oh my… I couldn’t find that card at the time :crazy_face:
Hi @Syswatch
It’s fixed as far as I could test, can you check?
Changelog Homey Pro v8.1.1:
  • [Apps] Fix an issue with error logging (GitHub issue).
  • [Apps] Improve stack traces when Device.updateCapabilityValue/setAvailable/setUnavailable rejects.
  • [Apps] Make “Homey.platformVersion” property available.
  • [Core] Update translations.
  • [Core] Add button CSS styling classes “secondary” and “danger”.
