Connected water meter
Hello, does anyone use a connected water meter? if yes which one and with what application.
my goal being to know if I have a water leak or water consumption on a secondary water network.
Thanks
Hello and thank you @Gruijter ,
it’s very complete but I just need to know if the water is flowing and if possible battery powered
Not affiliated in any way, it’s just a product I know it exists:
https://www.connectix.nl/watermeter-uitlezen-met-homey/
Or you can look to : HomeWizard Wi-Fi Watermeter - HomeWizard
You could add more then one meter to your account.
Good morning
I was thinking of something more with that and why not a sensor connected to it.
Powertool Water Flow Sensor Hall Effect Copper Flow Meter Water Flow Switch Fluid Meter for Water Heater Flow Measuring Device
Should work with this app
or a very expensive ready to go device:
https://a.aliexpress.com/_mqNmUX4 →
Of deze icm de youless?
https://nl.aliexpress.com/item/1005003961972441.html
Youless ?
Post #2 :wink:
Easy way is to install and use Homewizard
Watermeter Homewizard
Good morning,
Thanks for your response, but I need to know immediately if there is a leak.
I have no electricity at this level and the Watermeter solution gives this:
If an electrical outlet is not available, you can use 2 CR123A batteries (sold separately) for 1 year of historical data every 6 hours.
Drop these everywhere you could expect a leak: Aqara Watersensor | Zigbee | Wit Aqara 123led.nl
