I cannot connect connect aqara single rocker (no neutral) H1 switch directly to homey pro but the connection drops out. I can connect it via an m3 aqara hub and it works with the aqara home app but I cannot see the switch in homey pro or connect - do I need to reinstall the m3 hub via matter to bring in a new zigbee device to homey pro?
First of all, welcome to the Homey Community!
To make sure you are aware of the forum rules, please read the Welcome to the forum! post here.
When it’s connected to an Aqara M3 hub, it should/could be getting published as a Matter device (certain Aqara devices do).
In that case, you’d be able to add the switch to Homey using Matter.
To fix/improve your Homey zigbee network, first check if wifi 2.4GHz signal is not interfering with zigbee signal. This and much more info can be found here:
Thank you for your advice. I now have a stable network
