And if it is possible also the time that the timer is running (in a tile.)
So you can see, for example, how long the front door was open, if you have made a flow with a timer.
If this already asked and was not possible, sorry for asking again.
And maybe this is already possible I have missed it.
I just thought of the solution and created a ticket my self.
What we need is triggerflowcards that trigger each x [period] during when a timer/stopwatch/transition is running.
Kinda like the ones below, but not a one-type-trigger, but on interval while running (we already have started and stoped flowcards).
You could then set a Flowcard to trigger each 1 second that a Timer/Stopwatch/Transition is running.
As I was playing with it, @PV2134 had a similar question, and also wanted to know if displaying a timer value by a slider is possible.
It is, with the Device Capabilities app and the Chronograph app.
(note, the .gif recording is not realtime)
The slider settings:
The used flow (while Arie is busy with an in app solution?):
Hello Peter, I like your solution.
There are only some questions I have that belong to the shared device.
In the web app I see the status. In the moble app I dont see the status. And ther is no difference in stating yes or no.
What do I miss here.
Next question is, is there a way to get the value of the slider?
The idea is to set the the timer on the setting of the slider.
The mobile app often doesn’t show (your new) the status field by itself. In these cases, you’ll have to pick the status indicator yourself.
Sometimes you also need to enter some other zone and go back to ‘activate’ it.
Ah, had a hard time what you meant with this, but suddenly I got it. You meant setting the Optionally update mobile app to Y or N in the flowcard
I think I haven’t seen this solution here.
I wanted to show my remaining time of a chronograph timer in an AVD tile in HH:mm:ss format.
So I used the Text field option in AVD, with the cool reflect option to include the chronograph timer and combined that with a BLL function named duration that transform the milliseconds chronograph value into the text string format HH:mm:ss.
It only shows a value when you move the slider. And it shows only with the mobile app.
The right screen at my screenvid shows the Homey app on an Android emulator You can see it at the start of the vid
