Is it possible/Howto start an action of an app from Homeyscript
Take for instance the Chronograph app, which allows you to start/manage timers.
I can get the App object in Homeyscript with Homey.apps.getApp({id:‘nl.fellownet.chronograph’});
But how can I start a timer with a certain timeout on this app?
Thanks!
When you run example-flowcard-list.js in Homeyscript, it generates all And and Then flowcards of your installed apps, which you can use in HS.
I searched for chronograph for instance:
Start or replace timer [[namedd]] / [[name]] with a duration of [[time]] [[unit]]
  "uri": "homey:app:nl.fellownet.chronograph",
  "id": "timer_start_v2",
  "args": [
      "name": "namedd",
      "required": false,
      "type": "autocomplete",
      "title": "Pick",
      "placeholder": "Pick or type"
      "name": "name",
      "required": false,
      "title": "Name",
      "type": "text",
      "placeholder": "Type a name"
      "name": "time",
      "title": "Duration",
      "type": "text"
      "name": "unit",
      "title": "Unit",
      "type": "dropdown",
      "values": [
          "id": "seconds",
          "title": "seconds"
          "id": "minutes",
          "title": "minutes"
          "id": "hours",
          "title": "hours"
          "id": "days",
          "title": "days"
An example of how to use it, this sends a push message:
Homey.flow.runFlowCardAction({
        uri: 'homey:manager:mobile',
        args: {
			    user: {
			    //name: 'John Doe',   // optional, the 'id' and 'athomId' are key here
			    athomId: '5fxxxxxxxxxxxxxxxxxx',
		    text: 'Test push notification from HomeyScript test_pushmessage.js'
  return(true);
Thanks a lot!
